AUTO DOWN switches on all windows?
Old Jan 23, 2005
Dirty4Door's Avatar
Dirty4Door is an unknown quantity at this point
i'm looking to install "auto down" switches on all my of my power windows...but i can't seem to find anything on individual switches or components of the "auto down" system.
does anyone know of how to do this?
Old Jan 24, 2005
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
I know that you can add a window control module from DEI, part number 530t to your car to have your windows roll up when you arm your aftermarket alarm. These modules have the auto down feature for every window that you hook them up to. If you want every passenger to have auto down then it requires that you run wires to every door. Kinda time consuming. But if you only want auto down then that is not required. Most of the wiring can be done in the drivers door. The nice thing about these is that they have auto up too. I don't think that you need to have an aftermarket alarm to take advantage of the auto up and down features, but obviously to have them roll up when you arm your alarm, you would first need an alarm.
Old Jan 24, 2005
Dirty4Door's Avatar
http://www.radiomancaraudio.com/DEI-Window-Modules.htm
Originally Posted by DEI 530T
Also automates factory power switches by providing full window travel by tapping the factory window switch.
so does that mean this DEVICE with regular power windows can be wired to each door to have auto down/up? i will do the time consuming work (over time) if it can be done.
also, seen any factory "auto down" switches? i already have the factory drivers side "auto" switch. now i need 3 more (don't need em, but would look cooler with the "auto" light on them when i get it done).
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
werdnahall
May 17, 2015 11:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
mwwhonda
Nov 7, 2001 07:24 PM
