Not getting any sound.
Old Jan 8, 2005
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
I just installed a stereo in a '95 Grand Am GT....there's no sound. I tried running the ground directly to the chassis, nothing. Ran a second ground, nothing. Cut the ground completely, still nothing, but the stereo still works. WTH is going on here? If anybody knows what's up, let me know...
Old Jan 8, 2005
Well are the speaker wires okay? Sometimes there's a loose connection in the harness. If the deck has power, the grounds are fine. So it must be speakers. Maybe check fuses, but doubt it. Is the volume turned up
Old Jan 8, 2005
evilone's Avatar
That's the thing, the deck has power without a ground! The speakers are fine, the wires are all crimped really tight....and the volume's maxed. No sound at all.
Old Jan 8, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Go over your connections with your speaker wires again, are you using an amp to your speakers? If so, check your signal outputs/inputs, Check the resistance in the speaker wires, Check the connections to the speakers themselves.. if you still have nothing, it could be something internally like a blown transistor
Old Jan 8, 2005
mdb_foxmx's Avatar
mdb_foxmx is an unknown quantity at this point
I bought a Clarion unit one time, and it worked for a day, then the sound just stopped completely, yet the unit still had power. You can test the speaker outs if you have a small speaker laying around. When I tested mine, I still got no sound, and I came to the conclusion that the unit was a piece of crap...hope that's not the case for you
Old Jan 8, 2005
evilone's Avatar
brought it inside and bench tested it with a power supply.....all 4 speaker outs work. WTFH?
Old Jan 8, 2005
mdb_foxmx's Avatar
I dunno...that's really weird...well, I hope someone can help you. You should try and post on www.the12volt.com, there are some really knowledgeable people there.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
TheRiddicles
Sep 21, 2015 03:34 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Shadow277
Aug 31, 2015 12:30 PM
