New speakers = big hassle
Old Dec 27, 2004
pauldilsaver's Avatar
pauldilsaver is an unknown quantity at this point
So yeah, bought myself some speakers...6x9's and 6.5's...the 6x9's didn't fit thanks to the huge magnet....took out the trunk support...so now I'm putting in actuators to lift the trunk...yay!...not...so I go to put in the the door speakers and once again they don't fit....I'm a little stuck on the door delema tho...don't know what to do fiberglass or cut out the door metal...what does eveyone else do...pics...info...hate mail...anything will help me...thank you...
Old Dec 27, 2004
MRA's Avatar
MRA
MRA is an unknown quantity at this point
6x9's fit in the srock locations in my car no problem, as well as 6.5's int he front
Old Dec 27, 2004
Ed's Avatar
Ed
How are you attaching them to the doors, did you use a spacer? I just used a 1/2" mdf spacer cut from spare wood and my speakers fit fine. where in ohio are you?
Old Dec 27, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Trim the door panel to accomodate the magnet(if necessary), and cut a spacer/baffle out of MDF (whatever it takes to make it fit, from 1/4 inch up to 1 inch).
Old Dec 28, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
what kind of speakers did you buy that don't fit...brand and model number...chances are somebody on here will have first hand experience with the same speakers and will tell you how they did it. I have quarts and i cut away the metal with a dremel, many others have used baffles so there are many different ways of going about this.
Old Dec 28, 2004
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
i think these will work. my alpine type-s came with honda spacers so im not so sure.
http://www.crutchfield.com/S-QbOqQHO...3200&I=142SAH6
Old Dec 28, 2004
okay yeah...I think I got some spacers with the speakers....but I guess I overlooked that...so I guess I'll try that...thanks for the reminder and comments ....if I have anymore problems I'll post...until then thank you and for the person that replied where in ohio I live....uh yeah I moved to California...like a couple months ago...just haven't updated....
Old Dec 28, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
for the front i gutted the stock speaker then mounted my new ones to it.. then sealed it up all nice with a glue gun... fits like a glove.. if you cut the ring on the door pannle i think 6x9s could fit... ive got almost an inch of clearance between the magnet and the window..
Old Dec 28, 2004
WhiteRabbit's Avatar
if you moved to the bay area, I can help. so can that other guy whom I forget his name but used ot post here often, he lives about 2 blocks away from me
Old Dec 29, 2004
ToX's Avatar
ToX
ToX is an unknown quantity at this point
I made my 6x9 fit by bending a bit the torsion bar cause the magnet was so uge
I got diesel audio speakers
Old Dec 29, 2004
when I had kappa 6x9's I did the same thing. does your trunk close just like it did before? I had one iota of resistance at about 45 degrees closing if shut is 0 degrees and fully open is 90.
but it never had any real effect on opening or closing the trunk, definitely not on the quality of sound from the drivers.
is it the same for you? or do you not even have that much effect on the torsion bar?
Old Dec 29, 2004
ToX's Avatar
ToX
yeah, when I opened the trunk before it opened about a inch, now it opensaround 8 inch, and its a little stiffier but it is still ok.
Old Dec 30, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
popcorn touched on this - the speaker opening may have to be enlarged a bit to accomodate the width of the speaker basket. The spacer addresses magnet depth.
Note you should be able to enlarge it and still be able to revert to stock if you need to - not that much has to be trimmed from the opening, just in case you sell the car and need to put it back.
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
anubis62
Sep 27, 2015 12:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
