Air/Fuel Gauge not workin
well, i got 3 gauges: air fuel, EGT, and boost, for x-mas and i was going to install them today but ran into a little problem with the air fuel gauge. i followed the DIY exactly for it. i dont know if this makes a difference, but i tapped all three gauges into 1 ground wire and used a positive 12v location of the yellow wire behind the cig lighter and as soon as i did this the air fuel gauge red the farthest rich that it could and i just assummed that was because i didnt do the purple wire for the o2 signal yet. so, i took the purple wire and ran it to the black wire for the o2 sensor in the engine and it still read full rich on the air fuel gauge even when i revved it and left it idle and everything. anyone know what the problem is or how i get it to work? thanks.
Those a/f gauges mess up your 02 sensor, and even then they're not accurate like a wideband is. If you insist on running one for the flashy lights that don't mean anything, get a new 02 sensor and only use it for the gauge.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
