Red substance from battery?
Old Dec 17, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I was looking under my hood and saw some werid red stuff on my battery on both the negative and positive. I quickly wiped it off and it was like blood red colored. Anyone know what is going on?
Old Dec 17, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
did you get your transmission fluid changed lately? I can't think of too many red things it could be. was it confined only to the terminals or was it on other parts of the battery?
Old Dec 17, 2004
wonderz's Avatar
wonderz is on a distinguished road
you sure you didn't accidentally cut yourself while fixing your car and you dripped blood there?
anyways, on the serious note, don't think there are any red liquid stuff around the engine bay... just wipe off.
Old Dec 17, 2004
Vinnie's Avatar
it was like residue...from what i have no idea, Ill take a pic later today and post it up
Old Dec 17, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
It was anti-corrosion stuff. Keeps the battery terminals from corroding. You should have left it on.
Old Dec 17, 2004
Vinnie's Avatar
^^^^ah crap...are u serious! i thought it WAS corroding...
Old Dec 17, 2004
corrosion would be white and green paste like stuff.
the red stuff keeps the air off the terminals, thus blocking the corrosion.
go to an auto parts store, buy some more, smear it on, cover the posts and metal clamps completely. The spray on type (looks like yellow clear coat) works well too.
Old Dec 17, 2004
wonderz's Avatar
if its anti corrison stuff, shouldn't u notice it a long time ago? i mean they don't appear out of no where, right?
Old Dec 17, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
good point
plus if it was anti-corrosion stuff, u would have known cuz someone had to apply it on. u sure u didn't apply, and just forgot u did
Old Dec 17, 2004
MegaHurtz's Avatar
coulda been from the factory
Old Dec 17, 2004
or an oil change place.
I guarantee you corrosion is not red.
http://www.ezred.com/termprotectors.htm
Old Dec 17, 2004
wonderz's Avatar
yea, corrosion's not red..
but wow, its pretty nice if they help put the anti-corrosion stuff when you change oil..
wait.. then don't they have to disconnect the battery? if you still have your stock deck, then wouldn't u need to punch in the numbers?
Old Dec 17, 2004
oh and to explain.
corrosion needs the acid and oxegen to corrode the terminals. if the terminals are shielded from air, they cannot corrode. so anything that keeps the air off will do this. the red stuff is a commercial battery terminal spray. I use the krylon batterys spray which looks like yellow clear coat, dries quick and dry, and people don't tend to wipe it off.
Some ideas. baking soda cleans up corrosion, but don't get it into the battery. In a pinch, Sprite will dissolve the corrosion and let the car start if you have a stuck/dead situation. axle grease, vaseline, etc, will do the same thing. Prevent air from reacting with the acid
having a car die just from the terminals corroding is a waste. just an ounce of prevention!
sch2cm
Jul 21, 2015 09:58 PM
Jul 12, 2015 11:54 AM
