Please help w/alpine amp install
Old Dec 16, 2004
patau13's Avatar
Big Member
patau13 will become famous soon enough
I got my first sub and it sounds great! so I am running it off my component amp bridged now, but i have a second mono amp i am trying to install. Basically the question I have is, how to get the power and ground wire into the amp. The alpines have an openning much smaller than pencil width that I am supposed to jam 4ga wire into? So i can't make it fit...8ga may fit btw, but it seems pointless to run 4ga all the way back and then use 8ga for the last few inches. Any suggestions? I was thinking ring terminal but the ring is too big. thanks.
Old Dec 16, 2004
craiger's Avatar
craiger will become famous soon enoughcraiger will become famous soon enough
Get a distribution block. One that goes from a 4ga into two or four 8ga outputs. Run one 8ga wire to the amplifier used for the components and an 8ga wire to the mono amp.
Old Dec 16, 2004
Try and find a shop to mod the spade terminal or shave some off to make it fit. Or maybe get an 8 gauge terminal and mod the 4 gauge one to fit on the end somehow. Also check www.partsexpress.com for some different terminal connectors.
Old Dec 16, 2004
patau13's Avatar
Big Member
Alright, I give that a shot, thanks.
Old Dec 16, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
They do make adapters that let you convert from from a larger guage wire to a smaller one. They kind of look like those adapters you put on a socket wrench to be able to use smaller sockets. http://www.cardomain.com/item/STIS48ADAPTPT
OptimisticWay
46
Oct 15, 2015 02:16 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
