How do I add additional speakers?
Old Dec 2, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
How would i go about sending a signal to any extra speakers that I would have? If I simply connect more wires to my amp, am i cutting the amount of power that is sent to each speaker? In other words, if i run 4 speakers off a two channel amp what happens?
Old Dec 2, 2004
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
depends on how they're wired. If your amp is 2 ohm stable, and you've got 2 speakers per channel, just wire them in parallel so the resistance drops...amp is stable, and with half the rated resistance, you've got effectively double the rated power...so you're getting the same wattage as normal.
Old Dec 2, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
why would you want to add more speakers? an ideal system is one that obtains the best sound possible from using the minimum amount of speakers.
Old Dec 2, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Pardon the thread interuption, but HondaSales, you happen to have a picture of your left side kickpanel?
Old Dec 2, 2004
WhiteRabbit's Avatar
let him add more if he wants.
most aftermarket amplifiers are 2 ohm stable stereo. if your amp has a "bridged mono" power rating, its stable at 2 ohm staereo. this means you can just piggyback a second speaker on each channel (just ONE extra, for two total!) and each speaker willg et the same power as before.
50x2 amp? each speaker gets 50 watts each, for a 100 watt system. add two more in parrallel in stereo? each speaker still gets 50 watts, for a total of 200 watts of stereo power.
Old Dec 2, 2004
evilone's Avatar
^yup.
Old Dec 3, 2004
Vinnie's Avatar
so why is it a bad idea to have more than just 4 speakers?
Old Dec 3, 2004
its a cost/benefit thing.
your stereo's midrange and highs are twice as loud, at the cost of destroying any posibilty of having a soundstage.
your classic battle between quality and quantity.
Old Dec 3, 2004
HondaSales's Avatar
i do but will have to find it. when i do, i'll pm you.
Old Dec 3, 2004
thom's Avatar
/////ALPINE
i did a thread on this kinda...
http://www.7thgencivic.com/forums/sh...+more+speakers
Old Dec 5, 2004
Vinnie's Avatar
honestly, i was thinking about putting in kick panels with some components. I didnt really want to remove the kicker k60s that i already have. But I was wondering if adding components would enhance my system...any opinons to if this would work or help?
Old Dec 5, 2004
to enhance tonality and clarity, replacing speakers will often provide a greater benefit than adding speakers.
if you are looking at volume level as the enhancement, I'd add as many speakers as you can fit, and leave the old ones in for sure.
Old Dec 5, 2004
Vinnie's Avatar
thanks ^^^ makes a lot of sense now, I guess i just need to do more thinking/planning before I do things.
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
carid
Sep 28, 2015 10:13 AM
Gsxtacy
Sep 12, 2015 01:09 AM
