0 gauge install (w/ pics)
Old Nov 29, 2004
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
Talking 0 gauge install (w/ pics)
Over thanksgiving break I finally got around to doing the 0 gauge install along with some other minor things. This is sorta the beginning of the sound system redo of my car. I forgot to take some pics of the dist blocks and amps and such. Tell me what you think of it. I know it looks pretty shotty under the hood. I plan on fixing that soon.
Pics
Old Nov 29, 2004
C2i0v0i1C's Avatar
SuperMODrizd
The page cannot be displayed
Old Nov 29, 2004
FIXED
sorry for the double post too.
Old Nov 29, 2004
C2i0v0i1C's Avatar
SuperMODrizd
looks good
Old Nov 29, 2004
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
very clean, and very helpful...great post...
Old Nov 29, 2004
Havok2k1's Avatar
Wicked Pissah Admin
did u run your power wire with the RCA's?
Old Nov 29, 2004
catalin's Avatar
catalin is an unknown quantity at this point
Nice work, but you should really fuse closer to the battery. I'm sure you can image what would happen if by chance you get hit on the front passenger side of the car.
Old Nov 29, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
looks good, but why did you run the ground wire from the battery? You'll probably get better performance using the shortest grounding wire as possible and grounding it to the bare chassis
Old Nov 29, 2004
No, I didn't run the RCA's with my power. My RCA's run down the passenger side of the car, not the center.
I plan on moving the fuse. The engine bay wiring needs to be rerouted so it looks better too.
I haven't noticed any difference in amp performance between when I had it grounded to the frame about 2 feet from my amp to now. I assume thats becuase there is so little resistance in 0 gauge. Also, there is more resistance through the frame than through a wire and there is also stuff attached to the frame that you don't necessarily want power traveling through.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
tuvok
Sep 25, 2015 03:13 PM
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
