Question about what amp to get for my subs
Type Skivic
From: Old Bridge, New Jersey/ West Virginia University
Alright, I'm about to order two Rockford Fosgate Punch 12" 1000 Watt Dual 2 Ohm Subwoofers that have 500 RMS. Now I'm not sure how many watts for an amp I'm going to need. Im thinking I'll need 2 channel amp with over 1000 watts since both will add up to that. Any help would be appreciated. Also, any recommendations on brands would be helpful. Right now I was looking at Legacy.
Get a 1 channel amp (mono) that puts out at LEAST 1000wrms, the subs can handle a litltle more if you are looking at a certain amp that is a bit bigger. As far as Legacy goes, I would avoid them with everything I got... the quality just isn't there. Try looking at Rockford for an amp so that everything matches up. The T1001BD would be a nice amp for you
Type Skivic
Recommendations on brands other than Rockford amps? My friend said they arent worth the money and they overheat
read above and use google or go to your local shop. or ask your all knowing friend..lol
an amp that puts out 1000 watts rms x 1 at 2 ohm
Power Acoustik works great for me...its a 2 channel and it puts out 1200 watts RMS and 2 ohm. It runs my 2 volfenhag dual voice 1000 watt 500 RMS subs so I think you will be fine. Just get a fan cuz it gets hot, never had it over heat tho and I use it alot.
redcloud
25
Aug 12, 2015 01:23 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
