semi DIY:Head unit relocation in 01
Old Nov 8, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
alright some of oyu may have seen my screen in this thread
http://www.7thgencivic.com/forums/sh...d.php?t=168077
some people wanted to know what i did with the headunit.
so heres a semi diy of pics to show what i did.
i took out the stock head unit and im running a EQ and cd receiver.
the eq is where the cig lighter was and the cd player is next to the ebrake.
so heres the magical substabce called bondo. im using the fiberglass version because it is a lot stronger.
here is the panasonic unit
first thing i did was cut the hole big enough to fit the head unit in.
test fit
once it fit i built a box for it
then assemble the box around the head unit
check to see it fits
then i started to secure the box to the console
after its secured all you have to do is fill in the rest, the way oyu want it to look
after that all you need it sanding and painting.
heres a pic of it in the car, the reason why my head unit is that high up is because of clearance issues with the ebrake. some head units may be smaller and not have to go that high.
pretty much the same thing with the eq, cut hole to fit, build box then bondo in. sand and paint.
all i need to do is sand and paint, i got sick last week so i wasnt able to finish it.
hopefully you guys wont kill my photobucket bandwidth.
Old Nov 8, 2004
alex053's Avatar
all that work for $100 worth of gear.
with your indash unit why do you need this unit? just for volume control and the occasional borrowed cd?
Old Nov 8, 2004
dannn's Avatar
unique conformist
yea i need some sort of volume control for my computer other than the OS's volume
Old Nov 8, 2004
fonto's Avatar
The LA Clipper
x2
Old Nov 8, 2004
dannn's Avatar
unique conformist
seriously this only took like one day it wasnt like a weeks worth of work like wha ti had to do with my computer.
h4ldol
Apr 24, 2017 08:16 PM
Cam Diaz
Sep 28, 2015 08:34 PM
General DIY
Sep 25, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
Bricoleur
Sep 9, 2015 12:23 PM
