aaahhhhh help me please ***update***
Old Nov 4, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
i just got done installing my hu in and everything seems to work fine. i start up the car and i smell burning. then my guage lights stop working. i double checked all fuses and they are all good. the hu is perfectly fine and still works right now. the problem is i dont know wat was burning. it seems to come from behind the hu. i cant figure out why my guage lights arent working. and when i turn on my headlights the emergency blinkers stay on constantly without blinking. help me please
edit- i just checked again and the problem is still there. now the srs lights stays on and the turn signals blink every five seconds or so. how can this happen?? just by the radio?? can someone tell me if this has happened to them before. this is a definite first for me.
Old Nov 4, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
maybe the illumination wire is shorted to ground behind the HU.
Old Nov 4, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
After checking your wiring,check both sets of fuses (in the car, and under the hood). Make sure you find the problem in the wiring first though cause if you replace the fuse, you'll just pop it again.
Old Nov 4, 2004
i checked all of that. is there a way my illumination swtich is fried? would that keep my blinkers on and my guage lights off?
Old Nov 4, 2004
ttt can someone tell me if this has happened to them before?
Old Nov 4, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
On the harness there is two wires that are for illumination. They feed the orange wires on the aftermarket harness. The honda wire colors are red and red/blk.
Did you hook up anything to the red wire? The red/blk wire is the illumination output. Red wire is the dimmer circuit. Hooking up a stereo to this wire will fry your dash board cluster.
Old Nov 4, 2004
yup i think that is what i did so what do i do in this case??
Old Nov 4, 2004
I never use the dimmer, ever. Matter of fact, I cut it off relatively close the the harness plug and put heat shrink tubing on it.
Old Nov 4, 2004
so do i need to buy a new cluster or what??
Old Nov 5, 2004
When you hook up a head unit to the dimmer wire, it grounds out the wire and shorts it out. That was the burning smell you had. It was the circuits inside the dash cluster (which holds the dimmer circuit).
Unfortunately, I would have to say that you need to disconnect the wire, and get a different cluster. Your best best would be to get one off of Ebay. 2001-2 same except coupe and sedan are different color, but you can switch out those parts. Just get one that has either a stick or automatic, to match your car.
I fixed one for a friend, but it took a couple of days soldering and such.
Old Nov 5, 2004
so why would my srs light and blinkers stay on?
Old Nov 5, 2004
The dash is a multiplex, meaning the cluster is all computer controlled. If the trace burns along with some other wires, it can cause it to malfunction in other ways.
A few other members have had this same issue when hooking up something to the red wire. All of them had to replace the cluster, then everything was fine.
Old Nov 5, 2004
f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K f@%K
there goes money down the drain all becausei wanted to rush the install
how much is a cluster???
i can swap it out with an 03 right??
Old Nov 5, 2004
01-02 have the same harness. 003-04 different. So if you want to keep it simple, stay within those years. A used cluster is going to set you back 50-100 on ebay.
Titleist71
Engine Swaps
31
Sep 19, 2004 12:49 AM
keffin
24
Dec 18, 2003 07:32 PM
