9833 question
Old Nov 4, 2004
tripledoublegs's Avatar
Euro-Spec
9833 question
I got my hu about 3 weeks ago, and I absolutely love it, but I do have a little problem with it. Every time I want to turn the volume over 23 (it goes from 1-35), the headunit turns off, and turns back on at 0. Now, I'm thinking this happens because alpine requires to hook up the power wire directly to the battery terminal, but I only hooked it up to the harness, like I had my old sony cd deck. Could that be the problem?? If so, I'll be buying a 10ga wire tomorrow. I only hooked it up this way because a couple members on this site also did the same thing, and I was in no mood to put a hole in the firewall again. Anyways, I would really appreciate if you guys could reply...Especially the people w/ 9833 and 9835 hu. Thanks
Old Nov 4, 2004
MegaHurtz's Avatar
go to www.canadiancaraudio.com and ask there, a lot of people with 9835 headunits and a few alpine dealers
Old Nov 4, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Installation notes indicate a direct connection to the battery is required due to high current draw, IMO that's probably why it craps out.
Old Nov 4, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
I have a 9835 on the factory harness and I have no problems. Sounds more like a bad ground issue to me. I would make sure your ground connection on the harness is secure, or re-ground to the chassis.
Old Nov 4, 2004
Euro-Spec
i thought it was the ground too, but it turns off exactly when I go over 22 on the volume.
Old Nov 4, 2004
drcivic's Avatar
drcivic is an unknown quantity at this point
what is your speaker configuration and amps?
Old Nov 4, 2004
drcivic's Avatar
oh, and does it do when the engine is running, off or both?
Old Nov 4, 2004
Mystic3030's Avatar
Going over 22 on the volume **** could draw more power than a faulty ground can ground out, causing the HU to reset. Try re-grounding it.
Old Nov 5, 2004
Euro-Spec
^^I'll do it tomorrow, but I'm also connecting it directly to the battery once I get some free time on my hands. BTW, just found out I can turn off my display at night... Really neat, since the blue was a bit too bright...
Old Nov 5, 2004
Mystic3030's Avatar
If you wired it correctly it should dim itself at night...or is it still too bright after dimming? I think the 9833 also has a brightness and contrast control for the display.
Old Nov 13, 2004
Adamb123's Avatar
Adamb123 is an unknown quantity at this point
Um where is the chasis located?
How do you turn the HU off during night time I have a 9833 with the same problem. I grounded it to the same place as where another ground was. I think it was for my alarm.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
