amp problems!!!!!!!!!!!
Old Nov 3, 2004
JoshLuke's Avatar
JoshLuke is an unknown quantity at this point
I have a JBL 1200 watt mono amp that I have not had any problems with for more than a year. I went to start my car and the battery was dead. I went to the trunk to get jumper cables and I saw that the power light on the amp was on. Now all of a sudden the amp stays on when I turn off the car! Does anyone know reason for the amp to stay on while the car is off. Also when I start my car I hear some thumping noises coming from my subs. Thanks Alot!!!!!!!!!!!!!
Old Nov 3, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
2 questions
1. are you sure it was the power led and not a protection led?
2. Do you have a capacitor?
Old Nov 3, 2004
MegaHurtz's Avatar
just check that everything is hooked up properly
are you sure it wasnt always on like that before? maybe the battery never died
Old Nov 3, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Make sure your remote wire is hooked up to a switched source.
Old Nov 3, 2004
MegaHurtz's Avatar
ya maybe the remote wire somehow came a bit loose and it could have bridged over to the power terminal?
even if it was the protect light it shouldnt be on if the amp is capable of turning on
Old Nov 4, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
definitely sounds like the remote wiring is wrong - it needs to be connected to a switched source not constant - or you'll definitely get battery drain. Switched means when you turn the key off, it turns off.
Old Nov 4, 2004
J187's Avatar
Unless it's hooked up to cap, hence my second question.
Recently, I saw that someone had their remote hooked up to a intelli-cap capacitor. It stayed on after the car was off. Funky wiring.
Old Nov 4, 2004
coop's Avatar
why would a cap be installed for a remote connection?
Old Nov 4, 2004
Ed's Avatar
Ed
The cap probably had some sort of LED display that needed to be remote turned on/ off, and they could have jumped it from there.
Old Nov 4, 2004
JoshLuke's Avatar
i checkeded all the wiring by the amp and it is fine. It is the power light that is on and i don't have a capacitor. I also have a breaker switch instead of a fuse on the power cable.
Old Nov 4, 2004
MegaHurtz's Avatar
check your remote wire, it HAS to be the remote wire, unless your amp is stupid and has found away around using it
Old Nov 4, 2004
Make sure the remote wire is hooked up at the other end from the amp to a switched source.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
