Who has a voltmeter for their audio stuff?
Old Oct 28, 2004
IronFist's Avatar
Why did you feel you needed one, where did you put it, etc. Please answer all followup questions you anticipate me asking
Old Oct 28, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
My battery terminal has one built in. Doesn't do me much good while I'm driving but it looks neat
I'm constantly thinking of getting a voltmeter and ammeter and that gauge cluster thing that lets you put them on eaither side of the cluster. But I haven't decided yet.
Old Oct 28, 2004
IronFist's Avatar
What does an ammeter measure?
I don't think that make that cluster for our cars, do they? If you have an 01 or 02 it would kind of block the water and fuel gauges.
Old Oct 28, 2004
tbaleno's Avatar
ammeter measures how many amps.
Old Oct 28, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
actually, an amp meter is useless on a car. It only shows when the alternator is charging, but does not show the status. A volt gauge is far more useful. I.e. 14 volts, everything is fine. Lower than 12, battery is discharging and alternator is not working.
Old Oct 28, 2004
shmik1's Avatar
i wouldnt mind getting an ammeter and volt meter that sits by the gauges.. but my radar has a volt meter on it, and the gauges + bezel piece or wutever u call it is wut like $50 total?.. but it'd b neat
Old Oct 28, 2004
My vafcII has a voltmeter, so I guess I really didin't need my old one.
Old Oct 29, 2004
tripledoublegs's Avatar
Euro-Spec
I'm thinking about getting the Audiobahn volt meter to go w/ my amp.
Old Oct 29, 2004
LudlamTheory's Avatar
i boogie for the raindrops
ive got one now, i wanna get two more for in the cabin. one to monitor my front battery, one for the rear, just so i can know if i've killed the battery/batteries
Old Oct 29, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I've got one in my GrandPrix and it's saved my *** a few times from a dead battery. Also pretty good indication of when your alternators on it's way out.
Old Oct 29, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
There are different types of meters. Overall though an ammeter measures amps. I think it would be cool to have one that measures the current draw from your amplifiers.
These guys make some cool stuff like that: http://www.dakotadigital.com/
Old Oct 29, 2004
MegaHurtz's Avatar
Old Oct 29, 2004
IronFist's Avatar
It would be cool if the head unit had a voltmeter built in.
Old Oct 29, 2004
MegaHurtz's Avatar
Hey that WOULD be cool, never thought of that...
I believe the AVIC-N1 has a few gauges, maybe a voltmeter is one of them
Old Oct 29, 2004
IronFist's Avatar
Is a voltmeter hard to install?
Old Oct 29, 2004
Easiest gauge ever. power and ground for the gauge, power and ground for the light (if backlight is separate).
Old Oct 29, 2004
IronFist's Avatar
Does it light up with the other gauges (when you turn the headlights on)? Does the dimmer switch on the dashboard control the light on those gauges as well? I was surprised that my dash dimmer switch didn't control the brightness of my aftermarket head unit, but it has it's own brightness control built in so it doesn't matter.
Old Oct 29, 2004
shmik1's Avatar
so any connection to a power source is plenty accurate? or are different sources more accurate than others?
Old Oct 29, 2004
alex053's Avatar
i have one. it was free.
Old Oct 29, 2004
takumi's Avatar
takumi is on a distinguished road
I have a portable multimeter
Old Oct 29, 2004
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
But with an ammeter and a voltmeter (providing you get digital for both), you can get a rough estimate of alternator wattage, so you can have a rough idea of alternator efficiency. This way, if your alternator starts to crap out, you'll know from the beginning, and you can replace/upgrade when you need to. Strictly a tool, and mainly for looks, but definately not useless.
Old Oct 29, 2004
evilone's Avatar
Me too. Gotta love digital electronics class.
Old Oct 30, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
The reason i got a volt meter was because one time i drained my battery while listening to my system. That scared me when i had to jump the car so i installed a volt meter so i could always check the battery.
I put the volt meter in the driver side vent. I used bondo and like sealed it in. I bought an S7 voltage, cuz i like the colors
sry i dont have a day time pix:
Old Oct 30, 2004
IronFist's Avatar
^ Does the needle light up, too?
Old Oct 30, 2004
Vinnie's Avatar
yea its orange, i think i took the pic w/o my car on thats why its dark and it reads 0 on the gauge
Old Oct 31, 2004
IronFist's Avatar
But the other numbers look lit up so I thought your car was on.
Old Oct 31, 2004
Vinnie's Avatar
The needle is orange, i guess its just not visible in the picture. Anyway i think the pic is with my lights on but not the car itself. I wired the gauge so that it illuminates when i turn on the lights.
Old Nov 1, 2004
IronFist's Avatar
Nice. Where'd you get that? What are the buttons for? M and S? Minutes and seconds?
Old Nov 1, 2004
IronFist's Avatar
Dude, seriously, that's tight. Where'd you get it?
Old Nov 2, 2004
IronFist's Avatar
^ bump.
