Stereo auto shut off and restart, HELP!
Old Oct 21, 2004
jackal903's Avatar
jackal903 is an unknown quantity at this point
i got a Panasonic stereo, but don't know why it will auto shut off and restart after i turn on the turn signal light. It looks like not enougth power for the stereo. And while the turn signal light is blanking, the a/c light will dim a little bit also(if i turned on the a/c). i just installed a Optima Yellow top battery last month. is it some problem with my alternator??
Old Oct 22, 2004
Ed's Avatar
Ed
It might be getting weak, do you have any trouble starting your car? How do you have the HU's turn on lead hooked up, straight to the normal wire on the harness [blue/white i think]. Also, do you have any other audio stuff, amps, etc?
Old Oct 22, 2004
jackal903's Avatar
after i change the battery, i don't have any trouble starting the car. and i hooked up my HU straight to the blue/white wire. i don't have any other audio stuff. The problem always happens on low RPM or while the car idle.
Old Oct 22, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
what wire did you hook up to the Blue/white wire? Are you saying you hooked the yellow wire from the HU to the Blue/white wire from the car's harnes? that would be wrong. Can't remember what the blue/white wire would be, maybe a speaker wire?
Old Oct 23, 2004
jackal903's Avatar
i have go check. i forgot also......
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Brandon Vlasak
Jul 25, 2015 07:25 PM
Smokahontas123
Jul 22, 2015 10:07 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
robbie374
Jul 7, 2015 02:56 AM
