adding more speakers
Originally Posted by irishtemper
If you can keep it above 4 Ohms, You can put as many as you want.
i boogie for the raindrops
Originally Posted by Regularjoe
Thats the key. If the deck is rated at 4 ohms ..... then you can add as many speakers as you want as long as the resulting ohms of all the speakers when wired up is greater than 4 ......
drugs are bad and make you give stupid answers... hehehe
Originally Posted by LudlamTheory
not necessarily
too high of a load can cause problems as well
remember the law of conservation of energy: energy cannot be created nor destroyed, it can merely change in phase
too high of a load can also cause in overheating
I know that dropping the ohm load increases the current, which increases the power output, hence why its bad, and things cook themselves on too low of ohm loads.
I assumed that increasing the ohms simply reduced current flow, hence reduced power. Therefor no chance at killing it. Isn't the worst case of this simply not hooking a speaker up at all, hence an infinite resistance.
Can you elaborate on this ...... never heard of that before.
I
I
wow... yeah... i smoked too much last night and entirely forgot what subject i was talking about
im editing myself
The LA Clipper
im editing myself
im editing myself
That is honesty for ya a$$
EDIT:
Drugs are bad ... Mmmm-k.....
solarpunk70
Apr 12, 2016 11:43 AM
