speaker sizes
Old Oct 17, 2004
*misslynn*'s Avatar
*misslynn* is an unknown quantity at this point
speaker sizes
i can't seem to find the specs anywhere--what sizes do i need to buy to replace the front and rear speakers? thanks
Old Oct 17, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
6x9 in rears and 6.5 in the front
Old Oct 17, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Assuming you have a coupe... But search the forums, brought up many times before.
Old Oct 17, 2004
thom's Avatar
/////ALPINE
coupe: front 6.5, rear 6x9
sedan: front 6.5, rear 6.5
there you go! easy as that
go to crutchfield.com to see which speakers fit
Old Oct 17, 2004
thom's Avatar
/////ALPINE
speaking of rear.....
i broke a sweat trying to instal rear speakers.
so hard. so narrow. so little room. so hot.
Old Oct 18, 2004
MegaHurtz's Avatar
That back window sure does act as a heat intensifier on a hot day.
After 2-3 rear deck removals I wised up and placed blankets over my back windows on hot days.
Old Oct 18, 2004
thom's Avatar
/////ALPINE
^hmmm.. does that reallly work?
every time i do something involving the back i fold down one side of the back seat and open the trunk and put a fan on the front door facing the back so it blows hot air out.
Old Oct 18, 2004
*misslynn*'s Avatar
thanks
Old Oct 18, 2004
thom's Avatar
/////ALPINE
no problem.
Old Oct 18, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
Ummm, even those sizes are correct, we have crappy speaker holes. Most 6.5 aftermarket components won't fit without modification. And not many tweeters will fit in the stock tweeter mount if you have an EX.
The rears are a pain too, because if you have a coupe, you do not have enough depth. The trunk springs usually touch the magnet causing clanking. Go to Crutchfield.com and enter the specs of your car. It will tell you what speakers fit without modification if your scared of cutting up your car. Otherwise, just buy good speakers, and get a good guy with audio to install them. Or spend a 1-2 days sweating in your car to setup your audio.
Old Oct 18, 2004
duyaknow's Avatar
What state is AB? Or is that in Canada? If your in California, I'm pretty sure a couple guys around here won't mind sweating in a car with ya Miss lynn. 2004 black SI is nice.
Old Oct 18, 2004
MegaHurtz's Avatar
It works pretty good... still gets hot inside but the difference is like night and day.
Old Oct 18, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Are you guys sure the sizes are the same in her Canadian SI Coupe??
Old Oct 18, 2004
MegaHurtz's Avatar
ya Canadian Si == American EX
Old Oct 18, 2004
J187's Avatar
Cool. I just didn't know if you knew it was canadien, eh?
Old Oct 18, 2004
*misslynn*'s Avatar
oh yah...i keep forgetting that canadian si is american ex. does that change anything?
Old Oct 18, 2004
*misslynn*'s Avatar
we already have 6 inches of snow....i dont think it will be too hot here
Old Oct 18, 2004
MegaHurtz's Avatar
the canadian si and the american ex are the exact same, the only difference (that I know of) is that one has an EX badge and the other an Si badge.
Old Oct 19, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
The Canadian Si has DRL and heated mirrors...thats the only diff.
UltraHDGames
Jun 8, 2016 05:16 PM
68camerors
Sep 24, 2015 06:18 PM
Gsxtacy
Sep 12, 2015 01:09 AM
