cap wiring?
Old Oct 12, 2004
civic2nr819's Avatar
civic2nr819 is an unknown quantity at this point
cap wiring?
I have a 1.0 farad fosgate cap. When I wire it do I just run the power and ground in and out on the 2 screws on top with ring terminals and then into the amp, or can I ground it seperatly from the amp.I have never used a cap before but I want to avoid the dimming lights.
Old Oct 12, 2004
MegaHurtz's Avatar
Ground the amp and cap with seperate wires but to the same grounding point. Run a power wire with ring terminal to the + on the cap and a wire from the cap + to the amp +.
Old Oct 12, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You can also get a ring terminal slightly larger than your power wires, say your powers are 4awg, get a awg ring terminal and you can crimp both power in and out to the same ring terminal to the cap if you want.
Old Oct 12, 2004
MegaHurtz's Avatar
That's a big *** ring terminal though, and I wouldn't put too much faith in that connection
Old Oct 12, 2004
J187's Avatar
Couldn't be more solid.
Old Oct 21, 2004
ntense280's Avatar
ntense280 is an unknown quantity at this point
Caps don't generally help with dimming lights for this problem you need to get a high powered altenator. A cap is designed to help keep the power of your amp running constant so your bass dosent bottom out.
Hqly2001
22
Jul 12, 2015 06:44 PM
JUNITO
Jul 9, 2015 08:36 PM
aultman1990
Jul 9, 2015 08:27 PM
Bounddyy
Jul 8, 2015 11:22 AM
robbie374
Jul 7, 2015 02:56 AM
