Headunit Problem with Pioneer DEH-P460MP.
Old Oct 4, 2004
robutek's Avatar
robutek is an unknown quantity at this point
I have this problem with the headunit I have for my 01 civic sedan. I wired all the headunit wires with metra harness kit from autozone. Everything is wired expect for the orange and orange/white wires since the deck doesn't have them. We'll, after I plug it in, everything seems to be fine, except my rear right speaker seems to have no sound coming from it. So I set the eq on the headunit to be only for that speaker, I don't hear any sound until the volume is up at 53. All the other speakers sound fine at the volume being at 23, but I can't hear sh*t from the rear right speaker. Does anyone know what the problem is? I am running on all stock speakers. Thanks.
Old Oct 4, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Check the wiring to that speaker. Maybe swap the right an left hookups for the rear just to test that speaker.
Old Oct 4, 2004
Yeah happens to me alot when the back speakers go off. It's always a loose wire.
Old Oct 4, 2004
robutek's Avatar
Just switched the rear speaker wires, now the rear left speaker has barely any sound coming from it. Also, the three ***** to the left, the top one doesnt light up anymore. If I were to switch back to the stock headunit, then all 4 speakers would work.
Old Oct 4, 2004
MegaHurtz's Avatar
are you SURE they would all work?
Old Oct 4, 2004
robutek's Avatar
Yes, I would go around and listen to all the speakers. And also feel for the sound. With the stock headunit, all the speakers play fine. When the new pioneer is hooked up, I get only 3 speakers sounding right, and 1 that is very low in sound. Would my wire harness be messed up? Since whatever speaker I hook up to the right rear wires, it would turn out that the speaker would be low in sound. Thanks.
Slow2k1Civic
Jan 1, 2002 06:51 PM
