Inverter suggestions, and wiring...
Old Sep 29, 2004
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
just wondering what inverters out there are good??? I here some people talking about video static, is that due to location or quality...
also how can I wire my inverter to power on only when i have my ignition on or, **** whats it called when u don't turn the key all the way, just to the first click...I had a mental block just now...
anyways help me out guys
Old Sep 29, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
ANY inverter can be installed good, you need to take some precautions as to location, wiring length, grounding points etc. The video static is dependant on 1) # of screens and 2) output capacity of the player. If the source has a strong output level, you can run up to 3-4 screens with no amplification. Anything over that you'll need a signal amp or splitter. As for location, mounting will be key. You can wire it to ACC with no problems. Keep in mind that the inverter will make some noise from the cooling fan, so you may want to mount in trunk as opposed to somewhere in the front of the car. Any other questions just ask.
Old Sep 29, 2004
djspot's Avatar
fuk tha man!
as for hooking up the inverter, do they have on/off switches or can u wire them like you wire your amps that have a "remote on/off" from the deck so that it only comes on when u turn the key?
Old Sep 29, 2004
djspot's Avatar
fuk tha man!
oh and as for what I wanna hook up, Im using the inverter for an xbox...what power of inverter should I get 300W or is that over kill?
Old Sep 29, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
If you're hooking up screens, xbox,etc. a lot of people end up with wavy lines through their screen . . . if you get this problem you might wanna invest in a "pure sine wave inverter" . . . my 2 cents
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
ktae13
Electrical
Sep 26, 2015 05:14 PM
