Does it work?
Old Sep 24, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
Does it work?
I am getting a new 7" monitor in the mail today and wanted to know a quick and easy way to test the monitor before I custom mold this thing to my dash. I have not even removed the factory stereo yet, because I wanted to at least have music while I am working on the custom dash piece. It would really suck If i did all the custom work and the monitor does not work and I have to send it back. Please, any info is welcome.
Old Sep 24, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Do you already have a dvd player for it?
Old Sep 24, 2004
MegaHurtz's Avatar
hook it to a battery charger or car battery and plug a 12v source into it
Old Sep 24, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Send it to me and I'll test for ya
Seriously, batt charger on low is best.
Old Sep 24, 2004
HEBEGEBZ's Avatar
thanks guys. look for my set up coming some. if this screen works i have a lot of work to do.
Old Sep 26, 2004
HEBEGEBZ's Avatar
What are the best wires to tap for a monitor?
Old Sep 26, 2004
MegaHurtz's Avatar
power and ground?
Old Sep 27, 2004
HEBEGEBZ's Avatar
yes, both
Old Sep 27, 2004
MegaHurtz's Avatar
Are you wondering what wires behind the dash to tap when you do the install?
Old Sep 27, 2004
HEBEGEBZ's Avatar
yes...
Old Sep 27, 2004
HEBEGEBZ's Avatar
i received my monitor friday. The ad said it had two video inputs but it only had one. Is there a way around this if i wanted to do the dvd hu and my xbox. A video switch or something. Or should I jus complain and send it back. Did not want to wait any longer to get this project started
Old Sep 27, 2004
MegaHurtz's Avatar
You can try tapping off the power and ground for your deck, OR you can use the power and ground off your cig lighter.
You really only need power, there is a factory bolt behind the dash that you can use for ground.
Old Sep 27, 2004
909's Avatar
909
909 will become famous soon enough
My first monitor blew because of the voltage fluctuation (crank/on/off).
Since you have an XBOX, why not run your power off your 12V rail.
Old Sep 27, 2004
MegaHurtz's Avatar
You can use a voltage regulator
and a monitor shouldnt blow because of cranking the engine, the power to it should have been cut during that time... wierd... how did you have it wired?
Old Sep 27, 2004
HEBEGEBZ's Avatar
The xbox is going in later. I don't have an invertor yet.
Old Oct 1, 2004
HEBEGEBZ's Avatar
ok if anyone still cares, everything seems to work fine. I hooked it up yesterday as a test run before I got started making the custom dash. Thanks for the help. By the way what is a volt regulator and do i need one.
Old Oct 2, 2004
909's Avatar
909
Electronics like steady power.
Your civic pumps out anywhere from 10volts to 14 volts (crank/on/off).
Your Xbox already pumps out steady power @12 volts, essentially a voltage regulator.
See what I'm getting at?
Old Oct 2, 2004
909's Avatar
909
Megahurtz, my first monitor blew because it was wired like this:
Power (fused) from Battery.
Switched via 40A Automotive Relay.
Switch trigger ... 1G2 (steering harness) to survive crank.
The monitor stayed on when parked, and continued to stay on _as_ you started the engine. It's handy when you're watching a DVD,... and you don't feel like watching it from all the way from_beginning_ ONLY because you have to start the engine to drive
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
