For those with large boxes
Old Sep 21, 2004
MegaHurtz's Avatar
How do you get your spare tire out or do you even care about it? What do you plan to do if you ever get a flat? Have you ever gotten a flat since you disabled access to your spare? How much of a pain in the *** is it to not be able to use it, how much does it worry you in your head that you might get a flat somewhere remote and be screwed?
Enough questions for you?
Old Sep 21, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Personally, my box isn't big enough to contend with the spare. However, I've been in the position before. Basically, you could always figure a way to have a set of tools to remove the box in the event of a flat. You could also just get AAA and just plan to wait. I had an olds with 2 15s in a monster enclosure in the back. I dind't like not having trunk space, but I never had a problem with the spare. I just used AAA the 2 times I got a flat. Also, my best suggestion is if you have a huge enlosure keep a can of Fix-a-flat in your trunk at all times. If you happen to get a small hole in the tire somewhere, fix a flat will hook you up til you get where you need to go. It works pretty well. All in all, don't think about the spare tire dude, think about the BASS! You're an SPL guy, spare tire shouldn't even be in your vocabulary, lol. At least you'll have good sound while you wait for AAA.
Jason
Old Sep 21, 2004
MegaHurtz's Avatar
But I can get my spare tire out now while hitting some okay numbers with a sensible installation that still has some cosmetic appeal. I was thinking about over the winter rebuilding box but I would STILL like to get my spare tire out, but I guess I will have to try and work around it... I could make a really WIDE and tall but shallow box and maybe even do a trunk shock DIY to get some extra height, and then put my amps on either side of my trunk and make a matching panel that goes in the middle to get the tire out. Better yet, I could try and rig something out of metal to move the spare tire forward a little bit so I could make my box deeper. Then I could make a cover for my spare tire and put some tools in there for show. Better yet, I could make a large cover for the spare tire well, still with 2 seperate panels on each side, and inside that cover, make a circular shaped cutout that I could carpet and put back in and take it out for shows and have just the tool kit showing through without all the ugliness of the spare tire well surrounding it. OR I could forget about the tools and put like distro blocks, line drivers, etc in there. Man that would be cool, I think I am really cooking with gas now!!!
Sorry I get a little out of control
Old Sep 21, 2004
faultyscrew's Avatar
faultyscrew is an unknown quantity at this point
My box is pretty large but small enough that the spare tire can be carefully manuevered out. I don't really worry since my spare can be used and I have AAA for that anyway. If I drove in an area that has tons of cracked pavement, pot holes, and broken glass all over on a daily basis - then I might think it's a pain to get my spare out - since I don't drive anywhere like that on a regular basis I'm not too worried
Old Sep 21, 2004
MegaHurtz's Avatar
Or I could make it one solid piece with the circular cutout in the middle and have it on hinges so the spare tire comes out easily and have no seams from having 3 different panels across my trunk. and then I could mount my amp behind the spare tire recessed from the false floor under plexi maybe with a logo cut out of the plexi to help the amp with cooling. Doing that wouldn't affect my idea with the sapre tire, i could just put everything on molexes to make it easily disconnect
I think I'm gonna be busy this winter
Old Sep 21, 2004
WhiteRabbit's Avatar
or you could relocate the spare tire.
I have AAA, myself
Old Sep 21, 2004
MegaHurtz's Avatar
That's kind of what I described in my rant...
Where else could I relocate it other than forward?
Hmmm I suppose I could always leave the spare tire in the stock location and just mount the amp towards the back of the car instead, it's a bit wider anyway back there so if I wanted to mount a long amp such as a 22" long PG Xenon 1200.1 it might be a little easier. I could even make some neat little legs to swing out and hold up the false floor... sweet
Old Sep 21, 2004
MegaHurtz's Avatar
How about a continental kit? =P
Old Sep 21, 2004
under the car, opposite to the muffler
Old Sep 21, 2004
MegaHurtz's Avatar
There is room? Or would I have to cut the spare tire well and weld it flat it something
Old Sep 21, 2004
alex053's Avatar
check the diy..i think theres something on it...
Old Sep 21, 2004
fonto's Avatar
The LA Clipper
AAA
Old Sep 21, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I had mine relocated under the car when I had the spare well glassed in. It was on the cable like on most trucks now a days. I bought the assembly off a wrecked truck in a salvage yard. The only thing that sucked was finding the turn mechanism at night behind the body kit bumper (it was vertical as opposed to horizontalls installed so the tool was sticking straight up and down into it (barely had enough room to get the tool in between it and the ground)as opposed to on a horizontal plane. Well worth it though for what I used it for (and I never had to actually use the spare when it was relocated).
Old Sep 22, 2004
Teh_Sare's Avatar
Bush fu(king party,mother fu(king hand job.
Teh_Sare is a name known to allTeh_Sare is a name known to allTeh_Sare is a name known to allTeh_Sare is a name known to allTeh_Sare is a name known to allTeh_Sare is a name known to allTeh_Sare is a name known to all
this thread makes me think of fellow Niagara region Gen7 member, Brian (whitecivic2k2) and his 150 pound JL sub enclosure. i'll have to ask him next time i see him what he's done with his spare.
Old Sep 22, 2004
MegaHurtz's Avatar
I saw a picture earlier tonight of a 7 gen trunk where he located the spare tire towards the back of the car more, so I know it can be done, the question is just how. It would be uber easy to get out too, I think I just have to work on my engineering a little bit...
Old Sep 22, 2004
J187's Avatar
Hmmm, can the spare stand upright in the trunk? You could always make a nice spare tire cover and mount the tire TO the box standing up straight. You know with a nice cover like on the back of a CRV.
Old Sep 22, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
well, for me what I did was get a rear strut bar and some universal tie down straps. I ran the straps around the strut bar and through the floor of the trunk and around my box. The setup looks pretty nice and to get my box out all I have to do is loosen the straps. Makes it easy to get to the spare or to empty my trunk if I need to do so. Another idea is to get 2 individual boxes and mount them in the back corners or the trunk (by the taillights) then build a hatch over the spare. Thats what I am gonna eventually do I think.
Old Sep 22, 2004
Rufus's Avatar
I have no room and only take it on trips. When I do take it, I put it right behind my seat on the floor. Oh, and I'd wrap a shirt around it first.
Old Sep 22, 2004
MegaHurtz's Avatar
yeah that's what i was thinking first, but I drive like a 1/2 hour down the freeway every day for work and school, so that's a fair bit of a trip on it's own and I'd hate to be stranded but I think my odds are pretty good, I don't see how there could be a nail right in the middle of the freeway that would find it's way into my tire. I do want to research an alternative to having to get at my spare tire in it's factory location though becuase once i figure that out my install possibilities are endless
Old Sep 22, 2004
LudlamTheory's Avatar
i boogie for the raindrops
just shove it in a plastic bag and leave it in your backseat. its still a 4 seater if someone sits on it
Old Sep 22, 2004
MegaHurtz's Avatar
Hmm... I am sure I will think of something
I still like my continental kit idea
Or maybe I could mount it under my hood, cut the hood out and create a fiberglass cowl to give a really mean look
Old Sep 22, 2004
J187's Avatar
Mount it to the back of the car like an old school caddy. HELL YEAH.
Old Sep 22, 2004
MegaHurtz's Avatar
that's what a continental kit is...
Old Sep 22, 2004
J187's Avatar
Oh, missed that. HA. Do it. Or, you could always get run-flats lol.
Old Sep 22, 2004
continental kit on a civic?
noooooooo thank you
and, i've tried, it doesnt fit upright in the trunk
Old Sep 22, 2004
mugenman's Avatar
"mmmBAHHHH" - vtec y0
i just lift up on that cardboard lifting my box up and just kinda grunt and groan till its out lol but hopefully ill never get a flat
Old Sep 23, 2004
MegaHurtz's Avatar
Some of us have extremely heavy boxes with even more electronics screwed to the side weighing it down even more
and J187, do they make Z rated run flats?
Old Sep 23, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Z rated tires are for 149MPH +....waste of money on a car that cant go above 130 downhill with a strong backwind.
I havent had a spare tire for a year and a half...only time it bothered me was when we drove 6 hours to montreal, so I just put one in the backseat under a bag.
Old Sep 23, 2004
MegaHurtz's Avatar
Yeah that's what I was thinking of doing too.
It would still be nice to have access to the spare whenver I wanted it, I'm an advocate for keeping my car 100% functional as it was from the factory.
Old Sep 23, 2004
J187's Avatar
235/55R17 is the smallest I've seen run-flats so far.
