Setting line driver
Old Sep 18, 2004
MegaHurtz's Avatar
Setting line driver
I just installed a new line driver but I need to know how to measure the output voltage so that I can set it correctly.
Any info helps
Old Sep 18, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Multimeter? I donno...i've never used a linedriver so I don't know how you would do that. You could try IMing Nick he should know.
Old Sep 18, 2004
MegaHurtz's Avatar
Who's nick?
Old Sep 18, 2004
Mystic3030's Avatar
ludlam theory
Old Sep 18, 2004
MegaHurtz's Avatar
That's what I thought
I'm like retarded though, I knew I had to set it to AC volts and give it signal, but it wasn't working before, but now it is. How gay is that???
Old Sep 19, 2004
Mystic3030's Avatar
it happens
Old Sep 19, 2004
MegaHurtz's Avatar
seems like only to me
I don't know wtf i was doing wrong earlier but i swear i did the exact same ****
Old Sep 19, 2004
LudlamTheory's Avatar
i boogie for the raindrops
your whole goal, is setting the amp gains as absolutely low as possible
do it by ear.
if it sounds bad, it's too high
multimeter wont quite work, youd require an oscilloscope to do it scientifically
Old Sep 19, 2004
MegaHurtz's Avatar
Well it can be more closely set buy a DMM than by ear I would think, because that way if I know my amps gain is variable between say 6.0v-0.5v of input, and I set the output voltage to 6, then if I set my gain at 0 it's gotta be pretty close to be "perfect" right? The only thing that I see that could still be off is little inconsistencies in the electronics, but it's gotta be pretty damn close doesn't it?
Old Sep 19, 2004
you never know sir. the inconsistencies have been known to be tiny or huge. ive seen amps rated to 4 volts that you couldnt clip with 13. oscilloscope or ear...
Old Sep 19, 2004
MegaHurtz's Avatar
yes sir
the show I was redoing my system for went down today, and I'm sad to report that I didn't to near as well as I thought. I think I did make a couple of mistakes, but even then I wouldn't have placed so there is no worries. My high score on the termlab sensor is 141.4 but today I got as high as 139.7. I was at least glad to see that my scores were consistent, but I realize now what I did wrong and will shoot for much higher numbers next season.
Anyways back on topic... If they were rated for 4 and didn't even clip at 13, then why not rate them for 13 or whatever they clip at? However I don't know how ratings are determined so I won't say much more on that.
Instead of trusting what the manual says I should set it to I should probably get off my lazy *** and do some research.
Old Sep 21, 2004
WhiteRabbit's Avatar
the human ear is the most sensitive piece of equipment in existance, properly calibrated....
Using an O-scope is a fun tool as well, you can start all the way at your source and find where the units clip at what frequencies all the way down the line through the speaker outputs even.
Its a rare system that has the ability to tune to ZERO clipping, however. the volume just ends up WAY too low. Only time I ever had zero clipping in my car was feeding 350 rms to each of my midranges, and 150 rms to my tweeters. In the end, it madae no sense, and I swapped equipment becuase of it.
A line driver typically is used for boosting the signal to prevent indiced noise in the RCA cable. Thus, the desired tuning goal, really, is to maximize the signal strength post line driver.
naturally, you wont want a small CD player signal boosted heavily by the line driver, since the small chatter present in all players would be heavily boosted as well. So you would want to get the largest output possible from your CD player without distorting that same signal, or adding noise or excessive clipping. remember, you can have minor midrange clipping and never even hear it, and you cna have MASSIVE sub-bass clipping and never know it!
from there, youve maximized your S/N ratio. The line driver can then further boost that signal to the limit of its ability, unless SQ be dammed. getting the right balence of radio volume to line driver gain to amp gain takes a bit of finesse, and a CRAPload of listening time. Grab a CD or two, a pot of coffee or 12 pack of Mtn. Dew, and let the fun begin
Old Sep 21, 2004
MegaHurtz's Avatar
In my car, YES, SQ be damned, damned all to hell!!!
Old Sep 21, 2004
crank that bitch......
Old Sep 21, 2004
MegaHurtz's Avatar
Old Sep 21, 2004
fonto's Avatar
The LA Clipper
What kind of line driver?
Old Sep 21, 2004
MegaHurtz's Avatar
PG TLD66
http://www.phoenixgold.com/2004/linedrivers.html
Old Sep 21, 2004
fonto's Avatar
The LA Clipper
Cool line driver...clip your ish to get the boom!!!!
Old Sep 21, 2004
MegaHurtz's Avatar
But not quite the type of boom I am hoping to achieve :P
Having a 6 channel line driver is nice because I can have 2 set for daily driving, 2 with the proper voltage at a certain frequency, and 2 with the proper voltage at another frequency or some other setting that I might want to use.
Old Sep 21, 2004
cdmx's Avatar
amazed at how much you guru's know
Old Sep 21, 2004
fonto's Avatar
The LA Clipper
Is that sarcasm?
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Matteo
Oct 25, 2015 05:46 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
supercivic01
South
Nov 30, 2001 11:27 AM
