something's wrong with my speakers
Old Sep 18, 2004
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
hey
well recently i took out my subs and was too lazy to put them back in and wire up the amp again, so i just turned my amp (DEI Viper 400.2), that powers the components (DEI Viper 650.2), to have a full crossover range, and turned the bass boost up some more. when I do this and i turn the volume up to about 16 on my kenwood HU, my passenger-side woofer makes really weird/strange noises. but until 16 it plays everything as it's supposed to be, so i'm guessing i didn't blow the speaker. only way i could describe the messed up sound is like something's vibrating a lot or maybe even touching something (what would a speaker sound like if its excursion caused it to hit a doorpanel?). all other speakers sound fine. i checked all the screws and tightened them a little more, but still the sound was messed up. could there be something loose? could the shop, where i had it installed, have done something wrong in making a spacer and installing the 0.25" thicker than stock speakers?
thx in advance
Axel
Old Sep 18, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Put your amp back to highpass, turn off the bassbost and see what happens. You shouldent be running speakers on fullrange unless you have an active or passive crossover and know how to adjust it.
BTW, it COULD be blown. I've had blown speakers play fine at low volume and sound bad as I turned it up.
Old Sep 18, 2004
iLLuMiNaTi's Avatar
but then wouldn't that mean that both my passenger AND my driver's-side woofers would be failing to play the music?
also.. what does a blown speaker look like?
Old Sep 18, 2004
You might see if the speaker cone is torn. Other than that, the sound just might be door panel resonance. They sell small pads that can be put behind the speaker and improve midbass.
deanaZoom
35
Sep 19, 2015 12:22 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
jpat21
Sep 3, 2015 11:32 PM
