Anybody good with box design software?
Old Sep 8, 2004
MegaHurtz's Avatar
I have specs for 2 subs and I want somebody to check them out to see if the box requirements would be close to the same for both...
If anybody can help, let me know and I will PM specs
Old Sep 8, 2004
Ed's Avatar
Ed
You could give WinISD a try, it's free
http://www.linearteam.dk/default.aspx?pageid=winisdpro
Old Sep 8, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Send me the specs, I'll tell you what I come up with
Old Sep 8, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
umm just post the specs man.
Old Sep 9, 2004
J187's Avatar
Post the specs, include as much as possible.
Old Sep 9, 2004
MegaHurtz's Avatar
Titanium 10:
Fs: 29.9 Hz
Re: 3.7 Ohms
Qms: 9.0
Qes: 0.422
Qts: 0.404
Vas: 28.46 liters
Mms: 168.36 grams
Cms: 168.4 uM/Newton
BL: 16.64 Tesla-M
SPL (1W/1M): 85 dB
Sd: 345 sq cm
Xmax (field): 35mm p-p
Xenon 10d2
Fs: 18.7 Hz
Re: 3.46 ohms (series)
Qms: 30.19
Qes: 0.43
Qts: 0.42
Vas: 43.97 liters
Mms: 277.7 grams
Cms: 260 uM/Newton
BL: 16.3 Tesla-M
SPL (2.83v): 85.31 dB
Sd: 346.4 sq cm
Xmax (measured): 40mm p-p
I just want the specs compared to see if the box for the Titanium is close enough to be good for a Xenon as well
Old Sep 12, 2004
MegaHurtz's Avatar
bump
can somebody help please
Old Sep 12, 2004
Ed's Avatar
Ed
Sealed? what volume box? I'm plotting them on winisd now. THe xenon seems to want .847 ft^3, the Titanium .487. The xenon seems like it'll hit considerably lower. The xenon in a .487 box will raise the qtc to .86, the titanium in a .847 box will lower qtc to .59. Honestly though, If you're going to seal them, a larger box won't hurt too much. get a .8-9 cu. ft box, and if necessary, you can put stuff in it to take up space, or, get a box around .6 cu. ft and polyfill it for the xenon, it shouldn't be too bad.
Old Sep 13, 2004
WhiteRabbit's Avatar
if you do decide you want to play with winISD< all you need to model FR in a given box is FS, QTS, and VAS
Old Sep 14, 2004
MegaHurtz's Avatar
I have them in a ported box right now, 3.0 cubes tuned to 34 hz
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
