Cutting the metal on the doors (Pics up)
Old Aug 25, 2004
fonto's Avatar
The LA Clipper
...Can I cut speakers holes in the doors with a standard jigsaw or dremel?
thx
Old Aug 25, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
A dremel or rotozip will be much easier than a jig imo, but any of those will work, providing you have the right blade on it.
Old Aug 25, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Dremel worked great for me. Used the diamond cutter bit. Noisy as all hell, but nice clean cuts.
Old Aug 25, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yea use a dremel......with fine teeth bit
Old Aug 25, 2004
ntense280's Avatar
ntense280 is an unknown quantity at this point
I would suggest using the dremel but a jigsaw with the right blade will also work.
Old Aug 25, 2004
doubledeuce2k2's Avatar
whatcha puttin in?
Old Aug 25, 2004
fonto's Avatar
The LA Clipper
Originally Posted by DoubleDeuce2k2
whatcha puttin in?
Speakers I show you after I put it in.
Anyway, can someone post a pic of the right piece to use for the dremel?
Old Aug 25, 2004
Mystic3030's Avatar
any "bit" style blade for cutting metal. Home Depot usually has them, either under the roto-zip or dremel brand.
Old Aug 25, 2004
fonto's Avatar
The LA Clipper
Like these?
Old Aug 25, 2004
MegaHurtz's Avatar
I used a jigsaw (on my old car) but I'm sure a dremel will work better
Old Aug 25, 2004
everyone puts speakers there, put in a fridge or something
like mystic said, they look like a drill bit. rotozip packs more oomph (5A motor vs. maybe 2A) but both should get the job done. those bits are a frickin rip though, be careful not to break too many. the cost of those bits may be one reason to use a jigsaw.
Old Aug 25, 2004
Mystic3030's Avatar
Fonto, this is the bit you want: http://www.dremel.com/productdisplay...1&Color=CC0000
Your link just went to the main dremel site, so I donno if you found the bit I just linked to or not. But good luck, and be carefull, thats gonna throw a TON of sparks.
Old Aug 26, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I recently purchased Kappa Perfect 6.1 and they didnt fit in my doors, I was warned strongly against cutting the metal in the door as it will rust very quickly.
Old Aug 26, 2004
Mystic3030's Avatar
So get some clearcoat or primer and seal the bare metal...no biggie.
Old Aug 27, 2004
WhiteRabbit's Avatar
I use a dremel with a cutoff wheel... jig saw or air body saw would work fantastic too
Old Aug 27, 2004
Perhaps its that I live in Canada, the amount of snow that goes down my door in the winter,just pray your door doesn't rust!
Old Aug 27, 2004
hell, I live in sunny california, ive noticed how easily the door corrodes compared to every other part of the car......
Old Aug 30, 2004
fonto's Avatar
The LA Clipper
Ok, so this is why I was asking about cutting into the doors...
I picked up the speakers for $109, and I picked up this JBL BP 180.2 amp for $109 too...
...The magnets are HUGE on the woofers...I am a little nervous about if I can do this right, and cut the right size holes
Old Aug 31, 2004
check my pics, mike. those are Gabi's doors, we added one inch spacers on top of hte metal, and was able to get the door panel back on just fine, no issues.
And that gave us enough space to fit Kodas in those doors. three inches of depth
its teh one on the left. your kickers will fit totally fine
Old Aug 31, 2004
fonto's Avatar
The LA Clipper
Cool, the main thing I am worried about is cutting the metal and getting the whole right. I like the way you did it with cutting the lines and hammering the edges out...it seems to make the most sense it I want to do it easily.
The good thing is that the speaker is only 2" deep...so there is a good chance that I may not even need a spacer
Old Aug 31, 2004
youll want one, it makes cutting the hole easier, and matching the speaker up to get a good seal
Old Aug 31, 2004
fonto's Avatar
The LA Clipper
Thanks WR...I made some spacers today out of 3/4" MDF...however, I won't be able to install the speakers until next week
Old Sep 6, 2004
fonto's Avatar
The LA Clipper
pics of the finished product...pics here
Old Sep 6, 2004
MegaHurtz's Avatar
Looks good...
3-way system now?
Old Sep 6, 2004
fonto's Avatar
The LA Clipper
Originally Posted by MegaHurtz
Looks good...
3-way system now?
Yeah, it's a 3-way
Old Sep 6, 2004
MegaHurtz's Avatar
How does it sound? I take it you don't have the tweeters up in the sail panels anymore
What deck do you have?
Old Sep 6, 2004
thejdog's Avatar
thejdog is an unknown quantity at this point
Stupid question probably, how did you get the spacer to stay on the panel? Also, nice setup man! I've always installed my own ****, but I've never custom made my own spacers or ****, just used the stock spacers, but I'm looking to get bigger front speakers.
jDoG
Old Sep 7, 2004
I hope yuou took lots of pics, I got WASTED at SQ this weekend for not having enough pictures.... even pictures as stupid as ones of the speakers in place to show that I put four screws into the speaker instead of two.....
Old Sep 7, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
good job man
Old Sep 7, 2004
fonto's Avatar
The LA Clipper
Man, I replied to Megahertz questions a few times and the site kept losing the post...so I gave up
thejdog, I drilled holes in the spacer and put a screw strait through it into the sheet metal.
WR, The only pics I took are on my SD webpage...I prolly should have taken more, but I hate taking pictures when installing stuff. I don't know if I am going to enter to many more SQ comps...I wanted to choose after that last comp to do either SQ or SPL...and I just don't have the time, money, and skills to compete seriously in SQ...SPL is a lil easier...but I am always shooting for SQL
