Are these any good?
Old Aug 23, 2004
civic2uner's Avatar
Are these any good?
They fit perfectly in the stock pod. I was just wondering if they were good because I don't know alot about tweeters.
Also I have an amp pushing my door speakers and I have the tweeters wired in like the picture below. The tweeters come with a crossover and I didn't know how to wire the crossover in. Thanks...
Here are the tweeters..... http://www.onlinecarstereo.com/CarAu...roductID=11918
Old Aug 23, 2004
thom's Avatar
/////ALPINE
Go To A Autosound Shop And Test It Out.
Old Aug 23, 2004
MegaHurtz's Avatar
Since I am bad with xovers I forget how xovers connect, but I believe you will have a + and - in for the signal and + and - out to your tweeter. Just substitue one of the speakers in that diagram for your xover and run the + and - to the + and - on the crossover and then go from + and - on there to + and - on the tweeter keeping the same polarity
Old Aug 23, 2004
civic2uner's Avatar
but if i sub out a speaker, that speaker wont be powered by the amp.
would it be ok to hook it up with out the crossover?
Old Aug 23, 2004
civic2uner's Avatar
here is how i am currently wired up. where would i wire in a crossover?
And yes mega, the xover has a + and - input and a + and- output.
Old Aug 23, 2004
civic2uner's Avatar
how about this?
Old Aug 23, 2004
MegaHurtz's Avatar
That should work
czarlun
Jun 20, 2015 08:55 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
