Annoying problem...
Old Aug 16, 2004
MegaHurtz's Avatar
Annoying problem...
when I have my amp turned on, I can sometimes hear a slight rumbling or something from my subs, sometimes it seems like there is a low constant tone going thru them and sometimes it doesnt make any noise at all
the other day when i noticed when I turn my gain past a certain point i all of a sudden get the tone thing from my subs
What could be my problem?
Old Aug 16, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
I have the same problem...anyone know what it is??
Old Aug 18, 2004
booner05's Avatar
booner05 is an unknown quantity at this point
I had a similar problem occur with higher frequency noise when i used my laptop as the source for my HU and it didn't occur when i tried it with my friend's laptop. maybe there is low frequency noise from your source or bad conncections or a bad ground. I've heard noise induced from power wires close to signal wires and that is usually high frequency.
Old Aug 18, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
could be caused by many things...
check the ground first...
Old Aug 18, 2004
MegaHurtz's Avatar
Alls I did was turn down the level on my line driver the tiniest bit and the noise went away...
what's your take on that?
Old Aug 19, 2004
turboslug's Avatar
Super Hoser
where is you line driver located? is it far from the hu?
Old Aug 19, 2004
MegaHurtz's Avatar
Yes it is within 3' of my amp
As for another update, my noise started to come back today but it wasn't as bad as it was before... I am starting to suspect a bad connection on an RCA somewhere
Old Aug 19, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
sounds like a bad RCA.
Old Aug 19, 2004
MegaHurtz's Avatar
I would doubt it, my RCA's are top of the line
I think it's a shitty connection somewhere, my RCA's fit so tight they sometimes push the inner part of the female connector in on my line driver and I have to remove the case to make it fit properly. Maybe that happened and I did not notice
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
dlg1985
Jul 23, 2017 10:03 PM
haloway13
Nov 6, 2015 10:43 AM
Mc7602
Sep 17, 2015 02:01 PM
fvckbg
Sep 8, 2015 09:55 PM
