Good for grounding wire??????????
Old Aug 15, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
I am in construction, not too keen on electrical work, but I got some 3 foot clippings from the electrical company they threw away and was wondering if this wire, pretty thick i might add, is good for grounding?????? better than other wire????????? And if I add a second battery to the trunk, could I use it from the battery to the amp as a power and a ground??????????????
Old Aug 15, 2004
MegaHurtz's Avatar
Probably but not sure. If it's for 110 volt electrical system, it might not handle a high amperage, but it's probably good. The stiffer and more heavy duty looking the wire is the more current it usually can handle....
Old Aug 15, 2004
WhiteCastle's Avatar
Can you post a pic?
How thick is the wire?
Old Aug 15, 2004
one is 2 gauge i think and the other 2 are 0 gauge. Its the wires that go to the house from the pole, they have about 20 strands of wire inside of them. ill post a pic ASAP.
Old Aug 15, 2004
MegaHurtz's Avatar
You would be just as well to use wire that is meant to be used for car audio, personally I am a ***** for proper wiring and I wouldn't use that in my system
Old Aug 15, 2004
doubledeuce2k2's Avatar
i've used regular wiring and it works fine. the low strand count sucks to bend and everything (mine was 4 gauge, i can NOT imagine working with 2 or 0/1) but it all works the same.
Old Aug 15, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
if it's rated under American Wire Gauge standards, it should be fine as long as it's stranded copper wire...just make sure it's not aluminum or copper-clad aluminum...copper clad aluminum wire is a money saving cable for carrying AC current...there's no skin effect with DC current, so dont use the copper-clad aluminum cable..
i think the insulation should be thick enough since it's meant to withstand weathering, right?
Old Aug 15, 2004
and since it's only 3 feet it probably won't be subject to much weathering in the trunk
Old Aug 16, 2004
Yeah i never thought about that, the wire might be aluminum unless the copper clad is silver also, like I said i only did electrical in highschool, so I know basic wireing.
Old Aug 16, 2004
MegaHurtz's Avatar
What do you mean by "skin effect" with DC current, turboslug?
dinsum
May 28, 2015 09:30 PM
autowill
May 15, 2015 11:36 AM
Fastfebur
Apr 22, 2015 01:37 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
