Car Alarm
Old Aug 7, 2004
DVnAFI's Avatar
Tiene tremendo...CULO!
DVnAFI is an unknown quantity at this point
Car Alarm
Whats the best one? I want one of those cute little remotes that have like a LCD display,lol. But seriously, one with like sensors, and remote start, and one that can lower or raise windows....you get the idea. Whats the best one? 100.00 ones are crap, so, Im looking for one no less than 200.00 bucks. Thanks!
Old Aug 7, 2004
Mr.Modify's Avatar
get a viper 791 nuff said.......
Old Aug 7, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
none are good because if they want inside your car bad enough they will get inside.. but hey what do i know i have just worked in law enforcement for 5 years and havent seen anything like that first hand.
Injen
Old Aug 7, 2004
DVnAFI's Avatar
Originally Posted by Mr.Modify
less then a hundred bucks?!?!?! online? installation will cost more most likely (professionally)
i got the Viper 791 gots everything you need.....getting remote start installed soon.
I didnt say less that a hundred, I said no less than 200. So meaning something more than 200 bucks.
Old Aug 7, 2004
Mr.Modify's Avatar
either you changed it or i read it wrong...updated my post above.
Old Aug 7, 2004
DVnAFI's Avatar
791?
Old Aug 7, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
he's right - I just got a Viper 791XV and paid $715 for remote start, keyless, and to have one of the button combos turn my rear defroster on...I also had an button installed next to my cruise control switch that lets me pull the keys out and keep the alarm armed and the car running. Our big convenience store in NJ is "Wawa", hence my installer calls it "The Wawa button", theory being for running into the store real quick. You can also get a channel expander and have the 4-button remote do like 12 different things. I'm gonna have mine expanded to do the windows, pop the trunk, and the thing is so smart I might have one of the buttons find my zipper for me when I have to take a ****.
Old Aug 7, 2004
Mr.Modify's Avatar
791?
what don't u get?
Old Aug 7, 2004
DVnAFI's Avatar
well that sucks. On ebay you get one for 235 bucks and you get the window option and remote option for 50 bucks.
Old Aug 7, 2004
Karumba's Avatar
Boredom causes changes ;)
Parts fine .. but that doesn't include installation. Installation (and warranty) is mainly the price difference.
Also, just my opinion, but a good alarm is only as good as its install. My $0.02 on the matter. Good luck shopping for an alarm.
Old Aug 7, 2004
Pharoh's Avatar
Bobaganoosh!
I agree.
Took me awhile to find where the guy installed all the ish for my system.
Old Aug 7, 2004
Mr.Modify's Avatar
yea install kinda costs....for a good job. that's what you want!! You can't have a sloppy job done.
Old Aug 7, 2004
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
find a place that sells the alarm you want and ask how much it is installed, then ask him/her how much it would cost to have an alarm you bought elsewhere installed....dont be surprised if the numbers are close.
all the money made on alarms is from the installation, so just do yourself a favor and get one from a good local place installed.
Old Aug 7, 2004
MegaHurtz's Avatar
Compustar 2WFM has got to be one of the best on the market.
I have never used the Viper so I can't judge, but I'm sure they don't cost 715 because they are crap.
But you cannot go wrong with Computstar 2WFM either
Old Aug 7, 2004
Pharoh's Avatar
Bobaganoosh!
I prefer the Clifford Matrix RSIII myself.
Old Aug 7, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
ok i work at circuit city and the installs at our place are relly good. they charge 140 for a full alarm install. i would check big name places like these because they warranty their work. also the 791 is prolly one of the bast you can get. i have the same one but paid ALOT less because i work there.
Old Aug 7, 2004
Flounder's Avatar
Flounder is an unknown quantity at this point
Python (Viper)
Python 881XP here....
Considering that Viper, Python, and Clifford are all made by DEI, you're going to find that the brands are almost identical. The Python I have is identical to the Viper 791.
I paid $500 installed; if I remember right, the install has to be done by an authorized dealer or the warranty is void.
The alarm is absolutely great...door / trunk / shock / hood / ignition, and I had remote start installed.
Next step is the proximity sensor...
-Flounder
Old Aug 8, 2004
MegaHurtz's Avatar
Proximity sensor is pointless for a Civic, it's suited for a car like a convertible or Jeep.
If the alarm works proper, then the alarm should be going off long before the prox sensor is tripped.
If anything, go with a glass break sensor, that way your whole interior is covered.
Old Aug 8, 2004
Flounder's Avatar
The problem I'm having is getting the shock sensor to register on light enough taps without having it go off everytime a truck drives by.
For work I have to park for long (12-15 hours) periods in a crowded lot, so I'm trying to find the best solution to keep people away without a ton of false alarms....
Old Aug 8, 2004
MegaHurtz's Avatar
Keep your sensitivity at a level where it goes if you knock in it, but not where it gets tripped with a feather touch. What I try and do is adjust mine so it warns you if somebody tries the door handle lightly, and goes right off if you pull it hard (I get paged both times).
When I try and adjust it so it picks up the passenger side as well it gets too sensitive on the drivers side (which is where the sensor is), so I end up just leaving it balanced to the one side...
Old Aug 8, 2004
Pharoh's Avatar
Bobaganoosh!
My alarm was at the point where moisture running down the window in the morning would set it off. The glass tampering mic is very sensitive.
Old Aug 8, 2004
Flounder's Avatar
Nice!
That sounds like a great scheme for setting it. It's been pretty tame this summer, but when the students come back to campus things will get a lot busier. I wish I could say everyone was honest and upstanding but I know better.
I didn't worry about the glass break sensor because I figured if someone was smacking it hard enough to break it, the shock sensor should catch it as well.
Old Aug 8, 2004
MegaHurtz's Avatar
There are ways to avoid the shock sensor going off
They are pretty elaborate, but possible none the less
Old Aug 8, 2004
slammedcivic85's Avatar
Member
slammedcivic85 is an unknown quantity at this point
i drive an 02 civic with a clifford G5 alarm with remote starter on my manual tranny that cost me 600 installed
Old Aug 9, 2004
DVnAFI's Avatar
I bought a Viper 691Xv. Same crap as the 791. Anyways, how do I make the alarm louder? I literally opened my hood, put my head towards the siren thingy, and its not even loud I wanna make siren go LOUD!lol. How do I do it???
Old Aug 9, 2004
Mr.Modify's Avatar
your gonna need to get a new siren.......or get your horn tied into it to....or get Air Horns....
Old Aug 9, 2004
DVnAFI's Avatar
theres like no little **** or something? I didnt pay 350 bucks for a silent itty bitty alarm,lol.
Old Aug 9, 2004
Mr.Modify's Avatar
mines the same way ...not sure where the **** is if there is one...im pretty sure he turned it up though cause i know on mine you can adjust it......
you paid for the pager and what not and all that good ****......just buy another ****ing siren....they don't cost much....
is it the 690? i never heard of 691?
Old Aug 10, 2004
Pharoh's Avatar
Bobaganoosh!
I put in a 2nd siren for backup but it runs in tandom with my primary. I have a volume control for my primary as well (Intelliguard G4).
I also put a piezo siren INSIDE my car. Any fukcer that's willing to blow a pair of eardrums is welcome to try and steal my head unit.
Old Aug 17, 2004
Benzboy429's Avatar
Benzboy429 is an unknown quantity at this point
my alarm is crazy you touch the tire and the alarm goes off and if its touched again the gov of california comes out and kicks your ***
