Help Amp Protection Light comes on constant
Old Aug 4, 2004
Sim012's Avatar
Sim012 is an unknown quantity at this point
I was just drivin home one day listen to my music as usual then all the suddent the bass cutts off and the protection light on my amp comes on.
The amp is an old school infinity beta digital 300 amp. Its been running great for a while and never had this problem. I checked the fuses and its fine. I have it wired to 4 ohm, so it cant be my wiring. THe sub im using is a 12" Adire Audio Brahma. I dunno wat it could be.
Old Aug 4, 2004
doubledeuce2k2's Avatar
check to see if the ground is loose
Old Aug 4, 2004
Sim012's Avatar
I checked the grounds.....its not that, Its all secure and stuff
Old Aug 4, 2004
MegaHurtz's Avatar
Was your voltage too low?
Let your battery charge for a bit and see if it goes away
Was the amp getting hot?
How much power does that amp handle? Brahma's are powerhouses so it could have been working the amp too hard and wrecked it.. god forbid
Old Aug 5, 2004
Sim012's Avatar
the amp can produce 1000rms at 4 ohms. thats how much i was sending the brahma. The Brahma's max is 1600 rms
CarStuff
Dec 6, 2020 12:52 PM
beveragemp
May 25, 2015 07:11 PM
WLakers
May 4, 2015 06:23 PM
twtron
Apr 17, 2015 12:09 AM
smmahan
Apr 15, 2015 08:17 PM
