Wiring up an amp to stock hu?
Old Aug 2, 2004
matt86's Avatar
matt86 is an unknown quantity at this point
Is it possible to wire an amp for subs up to a stock vp civic headunit? Thanks
Old Aug 2, 2004
zen_master's Avatar
is it actually possible?
Old Aug 2, 2004
MegaHurtz's Avatar
Yes
You need either an amp with high level inputs so that you can plug speaker wires directly into the amp, or you need a line level convertor that will convert speaker level signal into low level (RCA) signal.
Old Aug 2, 2004
zen_master's Avatar
actually, im refering to single channel amp for sub...hehe
Old Aug 2, 2004
Ed's Avatar
Ed
it would be just as easy as a two channel, etc amp. it's the same thing you could just connect one of the rear speakers, or if it can sum tbe channels, connect both.
Lopes101
Jun 7, 2015 08:04 PM
jackoncruzpr
May 24, 2015 12:24 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
smmahan
Apr 15, 2015 08:17 PM
