Power needed.
Old Jul 31, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Power needed.
Im installing a emanage, boost gauge, air fuel gauge, boost controller, and a turbo timer. I know you can get power from the fuse box but wanted to get some of your guys opnions. I was reading a diy on oil pressure gauge and he taped off of the power outlet in the center of the dash. Only problem is i have alot of electrical running off of that circuit already. Any suggestions would help.
Jeff
Old Aug 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
run a new 8 gauge line in from the battery for all your accessories. the whole kit with fuses and everything only costs like 20 bucks at walmart.
from there you can just get a barrier strip or something similar at radioshack so as to distribute it
Old Aug 1, 2004
MegaHurtz's Avatar
I recommend a small distribution block like you would find in a car audio setup.
For my neons, I use a 1x4awg in and 4x8awg out to distribute the power, and it works fine running 8 in and 16 out. The plus with those is that they have covers and they are really safe from shorting out.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
General 7th Gen
Jul 9, 2015 10:17 PM
