Amp Power Wire?
Old Jul 29, 2004
takumi's Avatar
takumi is on a distinguished road
Amp Power Wire?
I'm hooking up my amp and sub right now on a 04 Civic coupe. I can't find a space to get the amp power wire through the firewall. Here's a pic of what it looks like under the glove compartment. I took the screw off that metal piece on the right but it doesn't seem to open up. Where should I put my power wire?
EDIT: Also, where should I ground the amp? I looked around my trunk area and can't find a bolt to ground it. Do I have to run the ground wire to the outside of the car?
Old Jul 29, 2004
Sgt_BlaZe's Avatar
Sgt_BlaZe is an unknown quantity at this point
look left...pull the black mat up until you see the metal...then you'll se the the plug where you can run the wire
Old Jul 29, 2004
Sgt_BlaZe's Avatar
you'll see a whole group of wires....that's the best place. if you look in engine bay on the firewall you'll see all the wires coming out and the black rubber boot. hope this helps.
Old Jul 29, 2004
Mr.Modify's Avatar
mine power wire is actually ran through the firewall under the sterring wheel...and ground the wire to one of the screws to the car that seperates the trunk from the back seats.....it's like right under the carpet when you fold down the seats.
Old Jul 29, 2004
Sgt_BlaZe's Avatar
I put my ground wire in the same spot...works great
Old Jul 29, 2004
SiG's Avatar
SiG
i ran it through on the passenger side. i felt it was easier to work on that side cuz theres no fuse box, steering wheel, and everything else on that side. theres much more open space on the passenger side.
as for grounding, i put the seats down in the back and found a bolt and used it.
you may wanna try taking the rear seats out and using the bolts underneath the seats. then replace the seats when its fully secure. just some suggestions, good luck.
Old Jul 29, 2004
takumi's Avatar
OK, I'm gonna ground it to a bolt that separates the backseat from the trunk. I looked under the hood but couldn't see a place where a lot of wires were coming through. Is it the thing all the way on the left of the pic where all the wires are going through or do I need to pull the carpet up more to see it? That was the most I could pull it up, the rest of it is under the center console.
Old Jul 29, 2004
Sgt_BlaZe's Avatar
I'm pretty sure that group of wires on the left is the same one I ran mine through. I couldn't really tell where I was looking at in the pic.
Old Jul 29, 2004
Sgt_BlaZe's Avatar
Let me go take a pic of mine....
Then I can help you better...
Old Jul 29, 2004
Sgt_BlaZe's Avatar
I'm now pretty sure it's the same spot...
Here's a pic of mine...
Had to use my phone for the pic, so it's not that great...
Good luck. Hope everything turns out great for ya...
Old Jul 29, 2004
takumi's Avatar
Hmm, looks like it. I'm gonna go try to stick this huge 4 gauge wire through the small hole, lol. Thanks!
Old Jul 29, 2004
takumi's Avatar
Ahh, it's not working. The huge rubber piece on the outside of all the wires takes up the entire hole. I tried putting it in through the slit in the rubber but the wires take up the entire hole on the inside. Here's a pic of what it looks like. Any ideas?
Old Jul 29, 2004
Sgt_BlaZe's Avatar
cut a slit in the outer rubber and run your wire there...
that's what I did...
Old Jul 29, 2004
takumi's Avatar
Hmm, I don't think I understand you correctly. Because if I cut a slit, the big rubber will still block up the entire hole. And the inside still has all those wires going through which takes up all the space on the inside.
Old Jul 29, 2004
Sgt_BlaZe's Avatar
let me go take a pic from the engine bay...
Old Jul 29, 2004
Sgt_BlaZe's Avatar
it was hard taking the pics...
i hope they help...
i just cut a hole in the rubber and it fit for me...
made it through no problems...
wish i could help you more...
ID:	34351   Click image for larger version
Old Jul 29, 2004
Sgt_BlaZe's Avatar
i'm using 2 gauge wire...so i'm sure 4 gauge will fit...
Old Jul 29, 2004
takumi's Avatar
Did you cut it like this?
Old Jul 29, 2004
Sgt_BlaZe's Avatar
is that view from the floorboard?
Old Jul 29, 2004
takumi's Avatar
Yes, on the passenger's side. I don't know where it goes comes out into the engine bay yet, lol.
Old Jul 29, 2004
Sgt_BlaZe's Avatar
yeah, cut a hole like that...
there are two boot covers...
one more is inside the engine bay...
stick a screwdriver(long one) through the hole then go look inside the engine bay so you know where it comes out...
make sure to fix the boot back up when you're done...
by the way....
that boot on the firewall is a real pain in the ***!!!
Old Jul 29, 2004
takumi's Avatar
Hmm, do I need to make a cut on the other side also?
Old Jul 29, 2004
Sgt_BlaZe's Avatar
don't worry too much about the boot you're looking at now...
make the hole as big as you need...
if you mess it up you can fix it so now air gets in...
you really need find that other boot on the firewall...
it is a pain in the ***...hard to break through...
good luck!
i'm leaving work now, so i can't respond until tomorrow...
if you have any more questions...i'll respond tomorrow...
take care and good luck!
Old Jul 29, 2004
Sgt_BlaZe's Avatar
"now air gets in" should say...."so no air gets in"
Old Jul 29, 2004
takumi's Avatar
Lol OK, I'll try to rip up the carpet a little more to find the other hole.
Old Jul 29, 2004
MegaHurtz's Avatar
Just push it through on the right side of where that bunch of wires is. With large wire it might take a while, but it does work.
What I suggest is putting a straight piece of wire (like cutting the straight piece off of a wire coat hanger) and taping it securely to the wire, with the power wire an inch or so back from the tip of the coat hanger wire. Use it to keep the power wire stiff and it will be very easy to poke thru the firewall. I've done it on 2 7th gens now (including my 04 with 4 awg), and it works really well.
Also works well for running speaker wire into doors.
Old Jul 29, 2004
takumi's Avatar
Oo, good idea. I'm gonna try that tommorow, thanks!
Old Jul 29, 2004
MegaHurtz's Avatar
It's not easy, especially with larger wire. It took me a lot of work to get my 4 awg through, but I persisted and eventually it made it. When I did 8 awg on a different car, it was a lot easier, but still slightly difficult.
Just persist and it will eventually work.
Please be careful to avoid touching the factory wires with the coat hanger. The last thing you want is to cause a short in there.
Old Jul 29, 2004
takumi's Avatar
The factory wires have insulation, but I'll try to keep it away from them. Seems like you need a lot of patience, hope it all pays off in the end..
Old Jul 29, 2004
brash's Avatar
brash is an unknown quantity at this point
I poked a bent coat hanger through that rubber thing, taped on the wire, and pushed it through to the outside. No problem at all (4ga wire). At least, compared to getting the speaker wire into the door...
I suggest lubing up the wire with some silicon spray or something, as someone here suggested in another thread (after I was done with my wiring... ).
