I.C.E. noob question
Old Jul 14, 2004
civic2uner's Avatar
Well I gave up on the flase floor box, and I recently bought a couple of these... http://www.purecaraudio.com/index.as...OD&ProdID=2173 with this amp... http://www.purecaraudio.com/index.as...OD&ProdID=2168
I basiclly just need to know what is a good setup for this since I know nothing about them. They are DVC so I know you can wire them different. I just want it to be wired up right. Thanks.
It's not my bag baby!- Austin Powers.
Old Jul 14, 2004
civic2uner's Avatar
what are ohms? more= better or less = better?
Old Jul 14, 2004
fonto's Avatar
The LA Clipper
Not really better or worse...usually, you want to match the lowest ohm load that your amp is stable at with the combined ohm load of your subwoofers (or any speakers for that matter). Amps typically put out more power at lower ohm loads (ie: my amp puts out 600 watts at 4 ohms, and 1200 watts at 2 ohms).
...if this makes any sense
Old Jul 14, 2004
civic2uner's Avatar
yea kind of. i just dont know what any of my stuff is capeable of. if any one would be kind enough to tell me how they would set it up that would be nice.
Old Jul 14, 2004
doubledeuce2k2's Avatar
for most power you would wire each sub's voice coils in series, then in paralell to the amp. you would bridge the amp. each sub would see 200W continuous power, of the 300 max it could take. looks like you'd want a sealed box between .5-1.0 cu. ft, i'd try to be at 1 cube. or ported is a whole 'nother story
Old Jul 14, 2004
Ed's Avatar
Ed
or, alternatively, you can parallel each driver and then series them to the amp, it might be easier if your subs are farther apart, only one wire to go from sub to sub.
Old Jul 14, 2004
civic2uner's Avatar
can someone draw a diagram because all this talk makes no sense to me! hahahahahahahahahahaha
Old Jul 14, 2004
Ed's Avatar
Ed
http://www.bcae1.com/images/gifs/spk2dvcs.gif
Old Jul 14, 2004
Ed's Avatar
Ed
www.bcae1.com btw, great site, rea it all for any questions.
Old Jul 14, 2004
civic2uner's Avatar
which one of these is better?
ID:	32937   Click image for larger version
Old Jul 14, 2004
civic2uner's Avatar
Old Jul 15, 2004
civic2uner's Avatar
anyone?
Old Jul 15, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Neither, it depends on the amp. 2 ohms, 4 ohms, 8 ohms, none is better than the other ..... Where it matters is how its all connected to the amp.
Take this amp:
500x1 @ 2 ohms
250x1 @ 4 ohms
125x1 @ 8 ohms
Now for this amp what would you get? Personally I'd get a DVC 4 ohm sub, wired in parallel so it acts like a single 2 ohm sub, and gets all 500 watts. If you wired that same sub in series, it would act like a single 8 ohm sub, so it would only get 125 watts.
You want to consider the number of subs and the ohms so that when you do hook it up you can get to the lowest ohms that the amp is rated for.
Most monoblock amps put out max power at 2 ohms. Some of the new ones put max power at 1 ohm. If your amp is geared for max power at 2 ohms, but you wire it to 1 ohm, you will most likely fry the amp. Higher ohms than the amp is rated for is ok, the amp just puts out less power. Lower ohms than the amp is rated for is bad. The amp tries to put out more power, and fries itself.
Old Jul 15, 2004
civic2uner's Avatar
Take this amp:
500x1 @ 2 ohms
250x1 @ 4 ohms
125x1 @ 8 ohms
you seem pretty knowledgeable about this. in my first post you can see what i have, can you set me up with a diagram?
Old Jul 15, 2004
MegaHurtz's Avatar
Use this diagram here
That amp still isn't big enough to give those subs the power they will need, so you may experience clipping. If it is not too late, I would go for a more powerful amp that will put out at least 600-800 wrms.
Old Jul 15, 2004
civic2uner's Avatar
what is clipping?
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
wootah88
Jul 21, 2015 10:22 AM
