Amp for Components! Reccomendations Pls!
Old Jul 7, 2004
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Question Amp for Components! Reccomendations Pls!
So yeah, i'm the guy who wired my 6.5's the wrong way and the HU amp overheat and fried....so now I need recommendations on what size amp to get for all my components...and i am still using stock tweets...my Pioneer Premier 6.5's are 220 watts max....i know i need a 4-channel but wouldn't want too much wattage to blow my stock tweets...post ur opinions and suggestions...i'm headed out to work right now so leave me some feedback so i can read and respond later...payce!
Old Jul 8, 2004
MegaHurtz's Avatar
Phoenix Gold all the way
Old Jul 8, 2004
How would I run the wire from the amp to the 6.5's in the door panels? Phoenix Gold is good...but I'm running straight Pioneer Premier. I need more idea's and suggestions on wiring and size of amp to get. Thanks!
Old Jul 8, 2004
MegaHurtz's Avatar
So if you are running all Premier why did you even ask?
Just push the wires thru the grommets to get them in your door... I had to do it... twice... once for my 6.5" and one for my tweeter, it was a pain, but it worked.
What I did was use a razor to make a cut in the grommet on the inside of the door
Then I cut the long piece off of a wire coat hanger and I taped the wire to the... wire, about 3/4"-1" down to give the wire some poking power. You might want to try and bend the wire to conform to the curve it will have to take, but that is up to you.
Starting from the inside of the car, I poked it thru an existing hole in the grommet. I worked my way through, helping the wire on it's way by moving it and stuff when it got caught on the rubber.
Once I had the end of the wire thru, I grabbed it with a pair of plier and pulled it all the way through.
Lather, rinse, repeat.
It took me a while to get the hang of it, but really it wasn't that bad at all.
Old Jul 8, 2004
brash's Avatar
brash is an unknown quantity at this point
Someone in an earlier thread suggested coating the wire with a teflon spray, which I wish I had thought of before I ran my wire into the door. It gets stuck on the rubber and is a pain in the *** to get through there. Not impossible, but certainly something you wish were easier. I highly suggest using some teflon spray.
Old Jul 8, 2004
alex053's Avatar
pop that rubber boot out of the door and out off the car...then tape the wires together, squeez the boot thing together and run the wire through....its easy...
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Mc7602
Sep 17, 2015 02:01 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
