what do you think of my custom center console.
Old Jul 6, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
ok so here it is. my unfinished center console with the screen bondoed in.
i need to work out some bumps, paint and sand a bit more then im done.
I had to remove and fill in the three holes for the buttons in the middle because the casing for the screen goes where they were.
Old Jul 6, 2004
Cocky's Avatar
Cocky guys kick ass!
very nice.. make me one.
Old Jul 6, 2004
MegaHurtz's Avatar
Nice man, can't wait to see the finished product... how hard was it to make?
Old Jul 6, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
hope you popped out the climate control plates and didn't tape them,,,,,,,,,looks good though.
Old Jul 6, 2004
MegaHurtz's Avatar
I'm not understanding why you needed to remove those climate control buttons unless the shroud on your screen was really huge
Old Jul 6, 2004
chicohonda02's Avatar
Since 2002 Baby!
nice good job.
Old Jul 6, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I'm betting the ac control pod was removed because it appears the screen is a little larger, or positioned closer to them than the standard opening. That coupled with the recess and then the actual control pod on the back (not the buttons, but the other part of it) is touching it, or close to it. That's my guess. Looks good, just finishing work left.
Old Jul 6, 2004
Mr.Modify's Avatar
yea can't wait to see it finsihed!!
Old Jul 6, 2004
dannn's Avatar
unique conformist
thanks guys for the feedback!
this is my first bondo fabrication job.
it came out alright but i think it could be better but it will do.
truthfully it wasnt that hard. bondo dries really fast, within 20-30 mins, and the only hard part is sanding.
the reason why i had to remove the climate control was because the front plate of the lcd panel has buttons on the bottom and it extends more than the top edge so it goes over the place where the climate buttons are. i cant just cut off the extra plastic cuz the screws that hold the lcd unit together screw into that portion of the lcd front plate.
here is a pic of it half installed. i still need to sand the paint so its even. the paint i bought was glossy but i didnt think it would have been this glossy.
Old Jul 7, 2004
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
wow thats nice! Good job
Old Jul 7, 2004
MegaHurtz's Avatar
****in sick dude... sick
Where are you gonna put your deck and climate control buttons now?
Old Jul 7, 2004
dannn's Avatar
unique conformist
i havent figured out where im gonna put the climate controls yet.
but i already relocated the deck to the place where the cig lighter is.
looks pretty ghetto but im not the type that care smore about funciton than form.
i just painted the bondo black, this pic was taken before it was painted.
pic of the back of the lcd.
Old Jul 7, 2004
might I suggest something? good. On your bondoing portion of your project, you might want to invest in a body file, for future projects. Another thing you might want to get, which makes your surfaces much smoother, and also fills pit marks is some finishing glaze. There are still some low spots that are visable, but I can see progress frmo teh original pic.
Old Jul 7, 2004
dannn's Avatar
unique conformist
thanks
i bought the putty for pinholes and bubbles but i found that its not that great at filling the bigger holes. if i can find another center console i might redo it later, i hacked this one too much.
well i learned a lot about bondoing.
Old Jul 7, 2004
PunkingCivic's Avatar
I need TP for my bunghole
not bad, but yes do another.
ps: I have attached a brighter image of the console.
Old Jul 7, 2004
dannn's Avatar
unique conformist
popcornplaya. i took your advice and got the file.
its a 4 in 1 design with 2 rasp 1 single and 1 double cut. i just finsihed filing down the sides.
i cant stand not being satisfied with my project so im over hauling it.
also im gonna get some flat black paint instead of this glossy stuff.
i just filled in the low parts and filed down the bumps. im waiting for the bondo to dry right now and im gonna go fill in the pinholes with the glaze. i'll take another pic after im done.
Old Jul 8, 2004
dannn's Avatar
unique conformist
here is the redone console.
middle of painting, putting on two more coats after this pic.
Old Jul 8, 2004
looks a whooooole lot better, and smoother.
Old Jul 8, 2004
Looks way better! That's a pro job and the flat black is also helping it.
Old Jul 8, 2004
zen_master's Avatar
good job! nice!
i wonder if there's a simpler kit to do this....u know, just plug in
Old Jul 8, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Looks much better! I was getting ready to call you red Fox until I saw the latest pic. Way to go.
Old Jul 8, 2004
dannn's Avatar
unique conformist
thanks guys
i just finished appliying the final coat. im gonna go over it with some rubbing compound to make it smooth. then i'll mount it in the vic.
Old Jul 8, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I'm doin the exact same thing... how did u get the deck to where the cig lighter is, doesnt that metal piece get in the way? or did u just cut it out
Old Jul 8, 2004
Props it LOOKS way better
Old Jul 8, 2004
dannn's Avatar
unique conformist
the metal piece gets in the way if you place the deck near the bottom of the cig lighter place.
if you place it in the upper part then there is EXACTLY enough room to fit it in. i'll post a pic soon so you get a better idea.
Old Jul 8, 2004
MegaHurtz's Avatar
when you say the cigarette lighter piece, are you talking about the kinda horseshoe shaped piece that goes around the center console and then curves up towards the dash and also has 2 little removable covers in there?
Old Jul 8, 2004
We need pics. I can't believe how good that center piece turned out.
Old Jul 8, 2004
MegaHurtz's Avatar
http://www.hzemall.com/mazda_mold.htm
Another example of how to do this... not in a 7g but you get the idea
Old Jul 8, 2004
dannn's Avatar
unique conformist
here is the final results
sorry for the crappy pics i took them with my sony clie,
head unit relocated. i didnt mold it all the way to the black part cuz im planning to get an aftermarket later on.
that black thing on the bottom is the IR sensor for the remote. i still havent found a place for it yet so i just stuff it in the little compartment under the head unit.
funny story, when i was reconnecting the HU back in the time was exactly 1:00 so the clock is matched up to the real time.
BTW my cup holders are useless!!!
i think once i get a smaller HU i will be able to fit cups in there again.
Old Jul 8, 2004
alex053's Avatar
so is it touch screen...whats the display source.
