One-Touch Sunroof
Old Jun 28, 2004
03HondaCivicEX's Avatar
03HondaCivicEX is an unknown quantity at this point
Question One-Touch Sunroof
Anybody know how to make our sunroofs into one-touch sunroofs? so you don't have to hold the button down while it goes back/up.
Old Jun 28, 2004
Mr.Modify's Avatar
damm that would be tight! "One Touch sun roof ..*Boop* leave it alone" <----from Pimp Juice by nelly.
Old Jun 28, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
That would be cool...I'd love it.
Old Jun 29, 2004
brash's Avatar
brash is an unknown quantity at this point
Ah, this would be a really nice mod...
Old Jun 29, 2004
zen_master's Avatar
nice..
but then, you wanna make it like the power window on the driver side..
so...if you push the button again, it should stop.
Old Jun 29, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Good idea! Let me know after you figure it out and get a diy for it.
Old Jun 29, 2004
ponyman's Avatar
ponyman is on a distinguished road
what about simply adding the relay from the drivers window to the sun roof control...would that possibly work
Old Jun 29, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
I brought up this a while ago, but no one could write a DIY on it. The way the driver's side window works is it measures how hard it is to pull the window down. That's why it sometimes stops; its sticking, and it thinks it has closed, because to it, 'closed' is when it gets to a certain difficulty to lower the window. This would be very complicated to do yourself, so I had the following idea: What if you did a time-related switch? Measure the time it takes for the sunroof to open. Say it takes 9 seconds. Make a button that, when you press it, the electronics simulate you pressing the button for 9 seconds. I would think that would be much easier, and not complicated to install at all once you find the right hardware. Just tap into the wire going to the stock button, and install the new button somewhere. The old button would work too like it always has. I just don't have the electrical knowledge to do this.
Old Jun 29, 2004
brash's Avatar
Alternatively, attach a bit of metal to two spots, one on the moon roof and the other on the roof of the car. Make it so when the thing is open, the metal bits make contact. Now make that complete a circuit, so you know when the moon roof is open, and when it isn't.
My electrical knowledge is not particularly great, either, but I might try doing something like this... it would be really nice!
Old Jun 29, 2004
tacheon's Avatar
tacheon is on a distinguished road
This can easily be done by rewire the switch to be momentary contact to ground. This can then be used to trigger a power window module. These are commonly used to roll the windows up on a car when you arm it. They work both ways. One model of alarm module is Clifford smartwindows, however Micro electronics and many others are available at a lower price. BTW, these modules can work independantly or with your alarm.
Old Jun 29, 2004
alex053's Avatar
ask bmw..they have them......let me think about this...i have some EE books and what not.
Old Jun 29, 2004
tacheon's Avatar
You want something like this http://www.autotoys.com/x/catalog/PO...OWS_p_313.html
They're readily available from just about everywhere.
Old Jun 29, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
I would say to get yourself a double poll, double throw relay, a micro switch and a new push button. OR look in the yellow pages and call a reputable sunroof shop. they might install it but help make a DIY also.
Old Jun 29, 2004
jwalker87's Avatar
Bodacious Member
hmm. This thing is only $20 and it says that it will roll the windows up when you arm the alarm. Would that include oem security system?
Old Jun 29, 2004
http://www.bestvwclub.com/howto/1touch/1touch.html
I found this also, might work on civics also, but not 100%.
Old Jun 29, 2004
CivicsRdBest's Avatar
Hmmmm That sounds like a good project if ya had the money for it...
Old Jun 29, 2004
tacheon's Avatar
I don't think the factory alarm has an armed out lead. So I'd say no to that. However, almost all aftermarket alarms have an armed out lead.
Old Jun 29, 2004
tacheon's Avatar
Don't use a pulse timer. That's not a good way to do it. The power window module detects a voltage drop as the load increases when the window/sunroof is in the fully opened/closed position. There is no setting of timers involved. The power window module also senses the load drop if something obstructed the window/sunroof from closing such as an arm, kid's head, etc...
Old Jun 29, 2004
tacheon's Avatar
That wouldn't work. You would still have to hold down the push button for the duration of the sunroof cycle.
Old Jun 29, 2004
ok newbe and whats your electrical background?
Old Jun 29, 2004
Pulse timer is adjustable, it's a timer and does not detect voltage drops TIMER!!!!!!!!!!
Old Jun 29, 2004
http://www.radiomancaraudio.com/deta...DUCT_ID=DE528T
pulse timer relay
Old Jun 29, 2004
tacheon's Avatar
I do work with power amplifiers for signal amplification of nerve impulses. I used to install car alarms for a local chain. I've used the clifford smartwindows module for power window automation. It's the easiest way to do this job. You will only use one output as there is only one window (sunroof) to control. A timer isn't a good way to do power windows because the time it takes for the window to close can depend on the weather/temperature as the sunroof may not slide as easily in colder weather and thus take more time. The worse thing that could happen with a timer is you arm your car or hit the button and walk away assuming your sunroof/window is closed when it isn't. Then rain has the oppourtunity to ruin your interior. Those timer modules are only good for keeping the light on. Like having your headlight or dome light remain for X number of seconds after you arm your car.
Old Jun 29, 2004
jwalker87's Avatar
Bodacious Member
so where can I can one of these clifford modules? and how much?
Old Jun 29, 2004
tacheon's Avatar
You can get these modules at a clifford dealer for $70 CAD but like I said, these no name modules do the same job. See the autotoys.com link above. There are other shops.
h4ldol
Apr 24, 2017 08:16 PM
SammySC
121
Apr 7, 2017 07:43 PM
EM2661
Sep 11, 2015 06:01 PM
First Car
Sep 8, 2015 08:54 PM
mrwhos
Aug 11, 2015 02:03 AM
