speakers with no mods.
/////ALPINE
crutchfield says the rockford fosgates will fit with no mods.
but do they sound good and clear?????
does anybody have these????
http://www.crutchfield.com/S-FTjeXyz...&avf=Y&search=
When I put in infinity kappas back there, I noticed the basket didnt clear, but was close. I just cranked the speaker down and warped the torsion bars.
the trunk still opened fine, just rubbed a little agasint the motor of the speaker.
it wasnt a perfect install, but it is a case of putitng a speaker in "with no mods" despite its large physical size.
The LA Clipper
/////ALPINE
well if someone put them in i am assuming they fit with lil problem? i trust someone else besides crutchfield.........they said only the slmin like reference speakers would fit in the front and there are so many differect options.
fronts have more issues than the back because of the small cutout and nothing to mount an aftermarket speaker to. If the rears have a depth issue, you can do the strut mod in the DIY......if it's height you're stuck because of the rear deck.
meicalnissyen
Sep 25, 2015 12:12 AM
redcloud
Sep 7, 2015 01:45 PM
t-bar will hit it when the trunk is open but closed you have about 5mm of clearance.
