Sealing Subs
Old Jun 23, 2004
harvichi's Avatar
harvichi is an unknown quantity at this point
Sealing Subs
I took a look at my subs, two 12" JL Audio, in a sealed box and noticed that the seal around the sub is not tight (I can see bubbles in the vynal going up and down around the edge of the subs). I tried to tightend the screws but the screws have stripped the MDF. Would it be OK to put a silicone strip around the edge of the baffle holes, so the subs can seal again it. Also, is there another way to secure the subs without simply putting wood screws into the MDF?
Harv
Old Jun 23, 2004
Ed's Avatar
Ed
mmm... T-nuts.
http://www.partsexpress.com/webpage....up_ID=259&SO=2
put one of those things in and use a bolt. I've heard great things about the Hurricane ones, although they don't look like they're work too well.
Old Jun 23, 2004
harvichi's Avatar
I must have had a brain fart when I was putting the box together
With the T-Nuts I shouldn't require any type of sealing medium, correct?
Old Jun 23, 2004
Ed's Avatar
Ed
It should seal, but if the basket isn't sealing you can get weather stripping from lowes or somethign and seal up the back
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
