boston acoustic pros
Old Jun 22, 2004
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
how is their build quality??
how do they sound compared to mb's focals, jl's..
is it worth it for a pair of used proseries 6.5 for 220US? possibly knock off 10-20 bucks...
Old Jun 23, 2004
LudlamTheory's Avatar
i boogie for the raindrops
for that price definitely, only problem, theyre power hungry mother****ers. ive heard of people running 300+ rms a side to them.
i wouldnt do anything less than 150 watts rms, if not 200 rms for them
loud as ****ing hell speakers
theyre good all around speakers, my opinion is just that they really dont excel anywhere above other products on the market for their going price. for the price youre saying though, definitely a good choice
Old Jun 23, 2004
BlueTroll's Avatar
okie great... but its a 3ohm speaker.... 4ohm ppi 4240 will cook.... even bridged i'll only have 120w per channel.
i emailed ppi, they said i'd need a fan cooling the amp.... for sure thatz a bad thing.
Old Jun 23, 2004
mohawkboom's Avatar
I used to run these speakers off an older PPI 2600.2 2X225wrms at 3ohms Amp never got hotter than usual and speakers took all the power.. more power you wanna run higher you set the crossover.
Old Jun 23, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I'm running 6.5 Pro comps from an Alpine MVR-F340 and they sound great!!
Ludlam - I'm aware of their high handling capacity, but is a certain amount actually required?
Old Jun 23, 2004
mohawkboom's Avatar
there's never a requirement for speakers. 1 watt will make any loudspeaker produce sound. however they are pretty inneficient and generally to get em loud and clean at least a 75Wrms amp works well.. Least amount of power I gave my set was 150Wrms to each side. got louder than I needed them to get.
Old Jun 23, 2004
fonto's Avatar
The LA Clipper
My friend has two sets of old BA Pros with 100 watts each of a US Amps amp...and they get obnoixiously LOUD!!!! ...and they hhe has had them for awhile; which speaks for quality and reliability. I think that some people would concider them bright, but I like bright speakers...I think that they have similiar characteristics to Quart premiums, but they can take more power.
btw, my friend crosses them over at like 220 hrtz.
Old Jun 23, 2004
BlueTroll's Avatar
hum.... so u guys r sure my amp will be able to hndle runnin the speakers at 3ohm???
i don't wanna make a mistake then end up frying my amp....
does bridging the amp cause the amp to get hotter?? cuz my amp is 4x30w and bridged is 2x120w...
if alls well with your replies i'll pick em up for sure...
Old Jun 23, 2004
fonto's Avatar
The LA Clipper
I dunno about your amp though...call PPI
Old Jun 23, 2004
alex053's Avatar
i had those running of an mtx 2300x..they took every bit of the 150 watts and wanted more..great speaker.
Old Jun 24, 2004
Astrodriver's Avatar
Astrodriver is an unknown quantity at this point
Just to let you know....the 3ohm rating is nominal.....if you take an ohmmeter and measure the terminal resistance of of any high-end speaker you will read a value between 3.1 to 3.8 ohms.
Old Jun 24, 2004
youve got it wrong sir... 3.1 to 3.8 meanss 4 ohm nominal
dcr of a speaker, or what you measure with a dmm, is its lowest possible resistance, its resistance at rest. a speaker with 3.1 to 3.8 dcr has a nominal impedance of 4 ohms.
these speakers have a dcr somewhere in the 2.x range, making them a 3 ohm driver
Old Jun 25, 2004
Thanks for the correction Ludlam....I always thought otherwise
AffliictiioN
Sep 16, 2015 02:21 PM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
