Civic 04 MP3 player
Old Jun 14, 2004
Hitesh's Avatar
Hitesh is an unknown quantity at this point
Exclamation Civic 04 MP3 player
I am planning to install a new mp3 player in my car - a black Honda Civic LX 04 Sedan.
Need a nice deal, and good quality is a must..
pls advice which ones are good ones..should support regular audio/MP3/CD-Rs/CD RWs and should be easy to install plus FM radio quality should be good.
I know i am asking for too much, but well..whatever.. links/advice/tips everything is welcome..
Also need to know if there is any kind of wax available for shining the INTERIORS of the car..
Old Jun 14, 2004
zen_master's Avatar
for MP3 player.....consider crutchfield.com if you want to install it by yourself..
or...IMO..
Circuit got this..
http://www.circuitcity.com/detail.js...&oid=87523&m=0
installed for free...+adapter & wiring harness...
or this..
http://www.circuitcity.com/detail.js...&oid=87376&m=0
for interior, im using ArmorAll....however, it's not the best protectant you can get out there....some other members will suggest more...
hope this helps =)
Old Jun 14, 2004
chrisleecool's Avatar
The one i was looking for was the Alpine 9833 they are very nice and pretty good price on Ebay. Those go around $450 on normal shops, but u can get them on Ebay for around $330. They are really nice u should go check them out.
Old Jun 14, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Alpine is very nice for MP3 playback...just be carefule though I got one and the display is a bitch to see!! Also check out Clarions! I use Meguiars dash trim foam for the inside of my car...works great!! Here are some links to better help you out....
Meguiars Link
Clarion Link 1
Clarion Link 2
Kenwood Link
Heard nothing but good about the Clarions and my brother has the Kenwood and it rocks too!
Old Jun 14, 2004
518's Avatar
518
518 is on a distinguished road
find the HU you want from Crutchfield or sounddomain.com (what fits my vehicle). Then go to pricegrabber.com to find it a little cheaper. Lastly, get yourself a wiring harness and install it yourself.
edit: oh yeah, I'm getting the Kenwood one.
Kenwood MPV8025
Old Jun 14, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
alpine alll the wayyyyyyy!
Old Jun 14, 2004
MegaHurtz's Avatar
Alpine or Kenwood or Clarion or Panasonic
can't go wrong with any of those
Old Jun 14, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
I'm an Alpine fan...and their Mp3 engine is excellent.
Old Jun 14, 2004
MegaHurtz's Avatar
vroom vroom
Old Jun 14, 2004
ALPINE all the way man..
Clarions are pretty nice too, but they don't look as good as alpines.
Also, don't forget to check out Ebay!!!!
Clarion745's run around 270's on Ebay I think.
Alpine9833's are about 330.(370including harness and wires for our car)
^^^^^^ those 2 are my suggestion.
Old Jun 14, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
zen_master, can you see your display from the driver's seat? I refuse to install a radio that does so many things better than stock, but can't even provide a usable display.
Old Jun 14, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Alpine Decks are great as far as MP3 playback goes. Another option you may want to check out are Pioneer decks(either of their lines, pioneer or premier). By far the best deck, that's non in-dash screen IMO is the P90HDD for MP3 playback. It has a 10 gig hard drive, accepts memory sticks, and has built in dsp. The downside to that is it's rather pricey (I've seen it on sale at a little less than $1100). Their new deck that may be worth checking into is the p8mp. It's not nearly as expensive as the p90. Some of it's features are BMX digital compression, SFEQ, IP-Bus sys control, and it's a different looking unit. Some more of their decks you may want to look into are the p960, p860, both of which have an upgraded multi-color organic EL LCD screen, among other new features. The most expensive of the last three I mentioned will set you back at most $450. Not sure what your budget is, so it's hard to say which. I've seen all of the alpine recommendations, so I didn't feel the need to reiterate those, I was just giving you some more decks you may want to check into.
Old Jun 14, 2004
MegaHurtz's Avatar
You can try Meguiar's (or Mothers, not sure) Back to Black for your dash. I've never used it but I've heard it's very good and I trust my sources. Armor All drys out your dash by absorbing the water and moisture in it, causing it to eventually crack
Old Jun 14, 2004
zen_master's Avatar
that's the thing....i suggested those decks....i really wanna buy it.....however, i'm still stuck with my OEM HU....LOL.
so, im not sure about it....the sony probably won't have any problems cos' the display's huge!
Old Jun 14, 2004
MegaHurtz's Avatar
Most Civic's have a visibility problem with ANY aftermarket deck because of the way the deck is placed in the dash. This is only apparent when the sun is shining directly into it, otherwise they are fine. The viewing angle is good and high enough that when not in the direct sun, they are awesome.
Old Jun 14, 2004
The dash angle sucks. A lot of the HU's are hard to see. That's a sacrifice you make I guess. I've, personally, never had a problem with the organic EL display on my dash. And then, once I flip flopped the pocket and the HU location, it was even better. I'd recommend anyone that hasn't yet invest in the two metra pieces to swap the pocket and HU's locations on the dash. It's still in plain view, yet is much easier to read in all viewing lights. Some might not have a problem with that, I didn't like the location, so I changed it.
Old Jun 19, 2004
VTEC01EX's Avatar
This pocket flip flop mod could be the ticket for me to get the HU I want. It's really a shame you don't have a digi cam, PopcornPlaya. I'd really be interested in seeing it, and I searched for pics of someone else's pocket mod and couldn't find anything.
Old Jul 22, 2004
Hitesh's Avatar
Cool Got Mp3 finally
thanx guys for ur reviews..
i finally got a Sony : Sony 52-Watt XM™ Radio-Ready CD Receiver with MP3 Playback and 3 Pre-Amp Outputs
Brand/Model: SON CDXF5700
i just got it today so will give u some reviews by next week
SSMatey
Apr 13, 2015 06:09 PM
bambuski
Nov 12, 2001 10:35 PM
EXWisdom
Nov 5, 2001 10:24 PM
WeRkX
Nov 1, 2001 10:33 PM
fordfocussucks
Oct 23, 2001 01:48 AM
