DYNAUDIO seperates
Old Jun 12, 2004
lvc2's Avatar
lvc2 is an unknown quantity at this point
DYNAUDIO seperates
Anyone tried to cram a pair of DYNAUDIO seperates into the doors on a 7th gen coupe?? I'm thinking that the 2 ways would almost REQUIRE Qform kick panels. For about the same money as 2 way seperates plus the Qforms I could buy the 3 way seperates & put the tweets in the sail panels (or on the door closer to the factory mid); put the 3" mids where the factory speakers are in the door & put the woofer in an enclosure with the sub since they only play up to about 170 Hz or so. Thoughs???
BTW: I know they cost too much. lol.
Old Jun 12, 2004
LudlamTheory's Avatar
i boogie for the raindrops
you do not want 170 hz in the trunk. definitely dont want it.
actually, the neo structure on dyn's probably makes em real easy to fit in the door
Old Jun 13, 2004
mohawkboom's Avatar
The DYn's fit into civic doors with some slight trimming of sheetmetal and the plastic ring on the door panel itself. The Dyns are euro 6 3/4" speakers. Basically trim the sheetmetal using tin snips to fit, add a 1/2" spacer, trim about 1/4" all around from the door panel ring itself and there ya go
Old Jun 14, 2004
holy christ. what the hell brings you back here don
Old Jun 14, 2004
fonto's Avatar
The LA Clipper
Woah!!!
...like a ghost came back from the dead!!!
Old Jun 14, 2004
lvc2's Avatar
clarification
Sorry guys, I should have been more specific. I've dynomatted & carpeted my trunk and typically ride around with the rear seat down. So when I talk about putting the woofers in the sub enclosure they wouldn't be in a closed trunk trying to play through the rear seat and/or deck. Thanks for the responses.
Old Jun 14, 2004
Ed's Avatar
Ed
them being behind you in the trunk would still wreak havoc on your imaging though..
And, WOW, MohawkBoom!!!!
He lives!!
Old Jun 15, 2004
mohawkboom's Avatar
Finally got over my sickness of computers and I'm back. I don't drive a civic anymore though but I install on em often. I ride a 2003 Golf TDI
Old Jun 16, 2004
Ed's Avatar
Ed
Nice, with those gas prices, and diesel always sheaper as far as i've seen.. you must be smiling. That plus real torque.. Glad to see you around again
Old Jun 16, 2004
doubledeuce2k2's Avatar
so you go from a torqueless wonder to a car with torque but no high end.... and i bet you care very little about that convert that baby to run on vegetable oil, i think thats the coolest mod ever.
oh, and welcome back
Old Jun 16, 2004
mohawkboom's Avatar
it's allready had the injectors changed, VR6 stage 2 clutch added and chipped. it's a 140hp monster with 265ft.lbs of torque. and get better fuel mileage than stock when just cruising on the highway.
EdGasket
Aug 29, 2015 09:58 AM
LikeWEEEEEEEEEE
42
Oct 16, 2003 09:36 AM
futurersxswap
Dec 2, 2002 12:04 PM
pinoyVTi
May 7, 2002 05:21 AM
Mussolini
Jan 28, 2002 07:42 AM
