2 amps
Old Jun 7, 2004
rolen91's Avatar
rolen91 is an unknown quantity at this point
2 amps
would it be safe to run two 800 watt amps on a stock 03 coupe battery. Has anyone done this already without a cap?
Old Jun 7, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
You should be just fine, but it won't hurt to get a better one.
Old Jun 7, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I'm currently running more than 2000W RMS off the stock battery. The only thing I did was run a properly fused 1/0 cable from the battery to a distribution block for my amps and 1/0 from the chassis to a distribution block for my grounds. My amps are hooked up using 4g (it is 4 4g runs each for power and ground).
I don't get any dimming. I think having big enough wire helps with diming.
My car still starts so I would guess I'm not doing much harm to the battery. Don't know for sure about what I'm doing to the alternator but time will tell if I'm over stressing it.
Oh. and I don't have a cap in that set up.
For reference the amps I'm running are:
Precision Power Inc PCX-2400
Rockford Fosgate 1050S
Alpine MRV-F540
Old Jun 8, 2004
rolen91's Avatar
thanks tbaleno and mystic3030, that helped
Old Jun 8, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
wire helps, but if u want to get the most out of the car, i would reccoment upgrading the ground, and using atleast a cap. i wouldnt worry about the batt. it is the alternator i would worry about.
Old Jun 8, 2004
tbaleno's Avatar
nuzio42,
I couldn't agree more. Except on the cap. I don't think you realy need them. They just look cool But thats a religous argument I probably shouldn't start.... Opps.. Too late. It just started
Old Jun 8, 2004
WhiteRabbit's Avatar
http://www.betteraudio.com/geolemon/newmain/battcapalt
server is down, give it a little time, it's a good read
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
