03 LX Sedan fuse box question
Old Jun 5, 2004
Change's Avatar
Change is an unknown quantity at this point
I'm looking for places I can tap into in the passenger compartment fuse box to obtain constant power and ignition-switched power. Does anyone have a diagram of the panel with descriptions of all the fuses, relays, and extra pins?
Old Jun 5, 2004
doubledeuce2k2's Avatar
what do you need to run?
Old Jun 6, 2004
MegaHurtz's Avatar
I'd like to get myself a copy of this as well... just for information purposes of course
Old Jun 6, 2004
Change's Avatar
Running power to a switch so I can select constant or ignition-switched power to go to a scanner (500mA power consumption), a large relay (~200mA consumption), and a cellphone hands-free kit (a few amps, I believe).
Old Jun 6, 2004
MegaHurtz's Avatar
Tap off the cig lighter wire
Easy to route the wires, depending on where you want to mount the scanner, mine is directly beside my cig lighter plug
Old Jun 6, 2004
i doubt you'd really want to tap constant power, one slip of the mind and your battery is dead. been there, done that. like said above, just use the yellow accesory wire, it can take the draw. for a SMALL constant draw i would say use the battery wire to your HU, but only for amounts under an amp or so, when the car is off, and only when you reeeeally needed it.
Old Jun 6, 2004
Change's Avatar
Yellow accessory wire being the one going to the cigarette lighter jack? Ideally I'd have something independent of that, I'd hate to have a device plugged into the cig. lighter that goes nuts and blows the fuse, thereby disabling my other accessories (the relay I mentioned earlier is a 75A continuous-duty relay that switches power to a number of devices in my trunk, to which I have run 8ga wire straight from the battery...I could get another run from the battery for constant power, but something from the fuse panel would be easier)
And yes, I do really want constant power. Trust me. I've done this stuff before and know what I'm doing
Old Jun 6, 2004
MegaHurtz's Avatar
You will need to run this stuff with your car off?
Old Jun 6, 2004
the purpose of a fuse would be defeated if you ran a 2 amp unit off of a 75A fuse... accessory fuse is something like 15A.
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
MiniMi
May 27, 2015 01:57 PM
smmahan
Apr 15, 2015 08:17 PM
cazminn
Nov 9, 2001 11:18 AM
