Question on the horn ASAP
Old May 29, 2004
civic2uner's Avatar
if i was replacing the stock horn with two new ones like in the DIY do you just tap the wire on the first horn and run it to the second?
Old May 31, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
I think it depends on how much current is being drawn, you could fry the relay or the wires and have a possible fire if you draw too much on one circuit. Someone correct me if im wrong but use a bigger relay or 2 one for each horn?
Old Jun 3, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
without a doubt you should use a relay. Purchase one that can handle the amps of both the aftermarket horns and use the cable coming from the OEM horn circuit to activate the relay
Old Jun 3, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
the cable coming from the oem horn may be a bit much (ampere wise) you may want to find the OEM switching wire that holds the oem relay open, it will be better in the long run, and probably have less problems.
Old Jun 4, 2004
catalin's Avatar
catalin is an unknown quantity at this point
Yes you'll be fine.
kaashifv
Interior
Jul 27, 2015 05:28 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
