custom trunk setup
Old May 13, 2004
RSXtypeIvtec's Avatar
Su Mo
custom trunk setup
My friends and I are going to build a custom trunk for my car
Going to be running 2 10in. alpine type r's and not sure which amp im gonna go with yet....
Can anyone give me some tips before we start on this project, cause i've never done this before, and i want to stay away from as many problems as possible.
how long did it take you to build one if anyone has ever done this?
what kind of problems should i watch out for?
anything you recommend i need to get?
thanks
Old May 13, 2004
AlpineCivic's Avatar
Biggest thing with doing custom work is: Take your time! dont rush. What exactly are you gonna build? False Floor? Fiberglass? you need to be a little more specific.
Old May 13, 2004
Su Mo
false floor....not sure if i want to mount my amp on the side or incorporate it into the floor, im not sure if i will use plexi glass or vinyl, def. not going to mess with fiberglass
Old May 13, 2004
False floors are not difficult, just make sure you measure and when your done do it again. Always double check before you cut. adding the amp to the false floor always looks nice, especially under some plexi.
Old May 13, 2004
tfnaaf's Avatar
BLDNPSI Mod
If you dont use fiberglass wont you lose a lot of usable air space? Im just thinking of some of the other false floor boxes ive seen
Old May 15, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
i think fiber glass is the way to go, you get the most out of the spair tire well and you dont have to cut a lot of difficult angles,...save you tons of time....
Old May 15, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
All in all it takes lots of time to do it right. My setup took me 3 days off and on, and thats with all the wiring run beforehand.
Old May 15, 2004
Su Mo
yea i have all the wiring already done, i just need to build the box and stuff...
Old May 15, 2004
civic2uner's Avatar
where do yall put the tire?
Old May 15, 2004
In the garage
Old May 15, 2004
civic2uner's Avatar
oh no thats no good
Old May 15, 2004
Su Mo
Originally posted by gearbox
In the garage
haha, yup
Old May 15, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Do what I did, build a custom ported/closed box that sits ontop of the floor and integrate your amplifier into the floor and cover it with plexi.
Old May 23, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
mine is very simple
http://i24.ebayimg.com/03/i/01/9b/05/0d_1_b.JPG
Old May 23, 2004
WhiteRabbit's Avatar
here is a neat concept:
when you build your false floor box, build AROUND the spare tire! rather than fiberglass the bottom, cut out two pieces parrallel to the seat backs, that fit into the spare tire well, and "wall off" the spare tire well front and back. its still metal on the sides and bottom, and the spare is still in it. these pieces you will bolt in place and silicone seal them.
now you cut out a piece of MDF that size (to cover the entire top and seal it) and mount your woofers in it, and maybe your amp on that board, too.
then grab some 2x2's and surround the whole thing on top. carpet it, and mount the speakers in it permanently.
now screw that piece of wood onto the top of the trunk, and your box is funtional! its as light as you can possibly get a speaker enclosure. check out one of my DIY's for making a false floor that sits on the 2x2's, and covers up the aesthetic trainwreck we called a subwoofer box
then, when you want to access your spare (and it will be a pain in the ***, but youll have it!) you can just pull out the false floor, unscrew the box top, lift it out or up, then you cna unscrew teh spare and pull it out from INSIDE the box!
besudes, if its pouring rain outside, your calling AAA anyways, right?
Old May 23, 2004
LudlamTheory's Avatar
i boogie for the raindrops
i put mine in my backseat in a giant trash bag
Old May 23, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
you could just relocate it to under the car. (spare that is)
Old May 23, 2004
thta only really works on coupes... sedans it will only fit on the direct bottom of the tire well, and that whacks speed bumps.
Old Jun 21, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
Can any one with a sedan post pics of their sub and amp setup in the trunk?
Thank you
Old Jun 22, 2004
Rufus's Avatar
I glassed my floor and got 4.1 ft3 out of it. Now it's tuned to 35Hz with 2 Diamond TDX 10's. Sounds great!
Old Jul 12, 2004
civic2uner's Avatar
so you know how to do this?
Old Jul 13, 2004
maxxam25's Avatar
mine doesn't need to bolt on to any of the cars body, I can just remove my custom box whenever and it's easy to do it....
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
