test for blown subs
Old May 4, 2004
jackscivic's Avatar
jackscivic will become famous soon enough
test for blown subs
i wanan know if there is a way to see if your subs are blown or if you have a paper rip. im sure this owuld be a good thing for everyone to know.
Old May 4, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
several different ways of checking to see if a sub is blown.
1. put a 9-volt battery to your sub and see if it pops
2. hook up a multimeter to it and see what ohms the sub has...should be the same as it is rated.
Old May 4, 2004
bizkit's Avatar
bizkit is an unknown quantity at this point
what if the sub is wired at 1 ohm but its reads 1.55 ohms from the mutimeter... is that bad
Old May 5, 2004
WhiteRabbit's Avatar
also, you can pull the sub out and shake it up and down, if you hear a rattle like a slinky inside the motor, the coils are delaminating.
Old May 6, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
if you just push the come in and you feel a grinding, that would be the voice coil, then that usually means its blown too.
Old May 7, 2004
renone's Avatar
renone is an unknown quantity at this point
multimete set to ohms test both sides of the terminals black to red red to black or vice versa just mesuaring resistance fingers off the contacts
should be withinn .50 of the rated ohms
dont push the cone or pop it with a battery
Old May 9, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i think DC resistance on a speaker can be slightly different than the rated impedance
go look at the spec sheets to see what the DC resistance is supposed to be
Old May 9, 2004
TeSt DrIvE's Avatar
TeSt DrIvE is an unknown quantity at this point
I believe if you pop the VC, their will be an extremely strong odour, like burnt musty smell
cyc
Jul 22, 2015 01:14 PM
breanna_17
Jul 21, 2015 04:01 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
AaronSorenson
Jul 7, 2015 09:40 PM
ZILLA
Jul 5, 2015 05:24 PM
