Makin the 12volt source constantly hot
Old May 4, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
I've searched and either can't pick up on the right key word, or its so far back in time I just didn't feel like searching past page 3.
I want to know if anyone has a DIY or work around that will keep the 12v cigarette adapter source hot after the key has been removed from your car. Right now I'm having to throw a shirt over my steering wheel with my valet key turned to the on position just to charge my cell phone.
Old May 4, 2004
HondaLuver's Avatar
Its a celebration bitches!
connect it straight to the battery
Old May 4, 2004
jackscivic's Avatar
jackscivic will become famous soon enough
you can also tap it into the fuse box under the dash. i think fuse spot 15 is a costant on circuit. id sugest wiring in a switch to turn it on and off sjut so you dont leave it on with something and drain your battery.
basically get some conectors, plug one end of it into the fuse box.
put an inline fuse it to save your car.
hooke the other end to a male connector and plug it in to the postiive slot on the back of the cig adapter.
thats it...
Old May 4, 2004
LudlamTheory's Avatar
i boogie for the raindrops
actually, i wrote up a diy on this long time ago about variable cigarette lighter "hotness" using relays
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
sesi
Oct 1, 2015 02:03 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bruce2
Sep 21, 2015 08:01 PM
