Good Distribution Block
Old May 2, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, basically I have a 4G power wire split up into two 8G power wires to power my subwoofer amplifier and front component amplfier. I bought a cheap distrubution block off ebay and im regreting buying it. The holders for the fuse aren't tight enough around the actual fuse so it moves around alot and frequently the amps shut off because they aren't getting enough power. Does anyone know a good distrubtion block that doesn't have this problem? Im thinking of going ahead and buying a stinger digital distribution block off ebay, but it uses regualr fuses that we would normally use in our cars, not the long tube ones. Would those fuses be hard to find in 40 amp fuses?
Old May 2, 2004
doubledeuce2k2's Avatar
if you have a fuse by the battery, don't bother getting a fused block. IMO it's a waste. if you don't have a battery fuse, get one.
Old May 6, 2004
shmik1's Avatar
I have Tsunami for my distro blocks and i've had no probs..
http://www.tsunamionline.com/power_d...ion_blocks.asp
9004 is similar to what I have..
Old May 7, 2004
jjj784's Avatar
jjj784 is an unknown quantity at this point
pinch the clips closer to hold the fuses tighter
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
usajags84
Apr 10, 2015 09:54 PM
